Bosch Logixx 6 Sensitive - Washing Machines
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Dec 22, 2010
SOURCE: F42 is showing on my
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Posted on Apr 01, 2011
  • 6277 Answers
SOURCE: Hello can you please help
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 12, 2011
Errore f43
Check motor connector block
Check motor carbon brushes
Oct 20, 2014 | Bosch Washing Machines
Hello can you please help me.. i have a big problem with my washing machine error on F43 Bosch logixx sensitive can you send me what the problem is.. Rune from norway
John C
Apr 12, 2011 | Washing Machines
F42 is showing on my Bosch Logixx 8 sensitive washing machine what does this mean and how do I fix it . thanks
Apr 01, 2011 | Bosch Washing Machines
My bosch logixx 8 sensitive front load washer is sayiing pump blocked and I can't find my manual. does anyone know how to address this problem?
I have a Bosch Logixx was bought in April 2009 and I have had this problem several times, it seems like a button or coin can block the pump, you may need to try turn machine off and pull out plug, take the drainage hose out of the holder, remove sealing cap, allow detergent solution to flow out, put the closing cap back on hose, carefully unscrew the pupm cver, see if anythings stuck there, re-insert pump cover etc. I have had to call repairmen out 3 times ( pump blocked not covered under warranty) and had pump replaced, I WOULD NOT BUY BOSCH ever againa s there after care service is rubbish and I paid $1800 for this metal junk.
Mar 09, 2011 | Bosch Washing Machines
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Bosch logixx 6 sensitive, is not drying and when you are taking some programs,he shows F:09 and stoped
Try taking of the back (middle) cap (torque screwdriver). On top of the heating element, you'll find a red (safety) button. Press till click sound.
That is all.
Aug 09, 2010 | Dryers
I need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Aug 31, 2009 | Bosch Washing Machines
Bosch logixx fridge/freezer
please contact authorized service center for repair
Mar 28, 2008 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
