Question about HEWLETT-PACKARD CP1525NW Laser Printer
I get toner residue on my paper
I have ran hundred of sheets of paper throught nut he magenta still shows up.
    Problem Solver:
  • 7 Answers
Most HP laser cartidges are an 'all-in-one' so the problem is likley to be the toner cartridge itself, either the 'wiper blade' or roller seal inside the cartridge has worn / failed.
Remanufactured and compatible cartridges are more likely to have this problem. If its a HP cartridge it will be covered under warranty.
Before you install your new cartridge make sure you remove all the toner cartridges and throughly clean the inside of your printer with a slightly damp lint free cloth & cotton bud.
Posted on Jan 02, 2014
My paper become polluted by color printing
Hi there!The problem is in you magenta toner cartridge.It happens when a cartridge is refilled or it has damaged PCR.The best way to fix this is by changing the magenta toner.If you have other questions pls feel free to ask!
Dec 18, 2012 | Office Equipment & Supplies
Pink edge shading
See if that is not pink spilled or destroyed ..
Jul 30, 2012 | HP Officejet 6500 Wireless All-in-One...
Xerox DC12 Error code 9-355
Error code 9-355 indicates, the magenta toner dispenser is broken and in need of repair.
Open the Front Door
From left to right, the Toner Cartridge colors are Cyan, Magenta, Yellow, and Black.
As a pre-caution, place a few sheets of paper on the floor, under the Toner Cartridge area, to catch any toner that may spill.
Remove the Toner Cartridge by rotating the handle to the left until the handle is in the unlocked position.
Pull the cartridge completely out of the machine.
Check for any obvious damage in the cartridge or printer and reinstall. Replace cartridge if damaged.
If error message continues, call a qualified repairman.
I hope this helps you fix your printer.
Jan 28, 2011 | Office Equipment & Supplies
My magenta toner "ran dry". I waited a couple of
hi there,
pull out all cartridge and shake it all than put it back.
This is because the toner to be solid, due to long period of disuse
Jan 05, 2011 | HP Color LaserJet 2600n Printer
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
Lines down the paper HP 4600DN
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Jul 14, 2009 | HP LaserJet 4600dn Color Printer
Printer changing color of paper
Make sure the transfer belt is clean. Also check the magenta cartridge and see if it isn't leaking slightly. By all means DON"T blow it out with compressed air! You may use a toner vacuum or a soft cloth to clean out any residual toner. If that doesn't do the trick, you may have a contaminated fuser. By the way, do you get the same effect when printing black and white?
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Bizhub C351 Magenta Image Unit Problem
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Jan 14, 2009 | Konica Minolta bizhub C351 All-In-One...
I have a HP 2600n Laserjet... When I print a sheet my red toner seems to bleed in the paper that I am printing on...
Try doing a few calibrations.If this doesnt work then change the Magenta cartridge. It sounds like the cartridge is faulty.
Jan 03, 2009 | HP Color LaserJet 2600n Printer
Hp 4650n
There is not clean cartrige button.
If you want you can try to remove the cartridge and clean it with a paper towel, and see if that helps get you to 300 more sheets, if not I would replace it.
Angela
Aug 12, 2008 | HP LaserJet 4650 Color Printer
HEWLETT-PACKARD CP1525NW Laser Printer Logo
52 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
