Question about Hobart A200 Stand Mixer
Oil leak on A200
I have an older A200 mixer bought at auction which leaks oil. I am familiar with the operation and know the mixer has seen little use. It is about 15 years old I believe. It leaks from the hub drive on the front of the mixer and it leaks underneath the mixer. Very slow leak but after several days I can wipe a drop of oil of the acorn nut that holds the shaft assembly (or whatever it holds) and there is a hole on the underside of the hub that also leaks oil. I see from parts list that there is an oil seal on the shaft assembly but don't see anything on the hub. Does the seal need replacement or is there a way to tighten the seal? How much of a job is it to replace the seal? Is there a seal for the hub assembly? Are repair manuals available? How do I know if oil needs to be added? Mixer seems to work fine but I would like to know that the oil level is correct. As you can see I have a lot of questions.
  • mariolavega Jan 31, 2009
    Have same oil leak problem and que.stions
  • olschool2000 Feb 12, 2009
    I bought mine from a used equipment supply discounted, but with no plates and therefore no serial, ML#, etc. They've since gone out of business. Are all A200 models basically the same?
  • 135 Answers
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Posted on Feb 04, 2009
Oil (or maybe broken down grease) leaking from the accessory hub of Hobart mixer.
You're right, it's broken down grease. The A200 doesn't have a rubber seal to prevent this from leaking, either. That's normally OK, when the grease in reasonable condition, but when it breaks down bad enough, you see what you're seeing. The grease needs to be changed which requires disassembly of the transmission. It's quite a job (and very messy) if you're not familiar with it, but if you're interested I know I've read (and may have written one) instructions on disassembling the transmission on this website. If you decide to do the job yourself, be sure to remove the attachment hub (comes out to the inside of the transmission) and clean the passage well.
Jun 09, 2010 | Hobart A200 Stand Mixer
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
I have oil coming from the front of a hobart a200 mixer,What to look for? and what kind of oil?
If you have oil leaking from the attachment hub, the transmission grease has liquified. The transmission will need to be opened so the old lubricant can be removed, by scooping it out. There aren't any seals in the attachment hub, just two torrington needle bearings. The helical gears thrust the pinion gear onto a thrust bearing in the hub to create a seal. The hub has a return hole in it's casting for excess lube to return internally. It's possible the return hole is restricted. On the other hand, if the machine has been filled with oil, it will probably leak like a siv.
The new lube should be 35 OZ of mobil XPH 222,
Hobart part number is 103881-47 for 32OZ.
Aug 04, 2009 | Hobart A200 Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
Mar 14, 2009 | Hobart A200 Stand Mixer
K45SS leaks lubricant
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
A-200 mixer oil leak
the trans uses all grease today hobart uses mobil lith aw-2 you can get the seal from any hobart office.
Oct 19, 2008 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
Jan 25, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
534 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
