Question about HP PSC 1610v All-in-One Printer
Black line when scanning or copying
When I scan or copy a picture or document, the printer leaves a thick black line down the middle...either on the printed copy, or the scanned image on the computer. There are no obvious marks or trash on the scanner lamp. When printing from the computer, it's fine...so I know it must be somewhere in the scanner.
  • Anonymous Mar 12, 2014
    I can print from my computer and copy from the scanner just fine
  • 31 Answers
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Posted on Jun 25, 2007
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
When I copy or fax with my 4215 it leaves a thick black stripe down the middle of the page, but not when I print off the computer.
There should be somewhere for you to open the printer to see the area that reads the document (might be a small strip of glass), there could be something stuck on this area (tiny spec the width of your line), thus causing the lines on the scan and not the prints. I am not too familiar with that model, so that is the best I have for you. Hope it helps.
Aug 24, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Thick Black line
This issue occurs if the scanner lamp is not getting enough voltage.
make sure that the printer isn't connected to a surge protector,
also you may try making a copy of any document.
this will be a hardware test, a reset of the printer might resolve the concern.
since the reset requires technical supervision,
revert back for further clarifications.
Ronald
HP AIO Support.
Jun 13, 2009 | Lexmark P3150 All-In-One InkJet Printer
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP PSC 1610v All-in-One Printer Logo
3,249 people viewed this question
Clive
Clive
