Question about HP Pavilion dv9000z Notebook
Hp dv9207us laptop motherboard troubleshooting
I have dv9207us laptop with me. it was suddenly dead. normaly i don't shutdown the laptop, same thing i did one night (just simply folded the screen it went to sleep mode) and opened the screen on the morning, it was totaly dead and some smoke smell has come and did the basic testing with these components (outlet, A/C adaptor, removed the battery) all are perfect, Then i have removed the battery and connected my laptop with the adaptor only...hmmm no use. No display. then I decided there is something wrong with the motherboard.
I have disasambled the laptop with the HP Service Manual. I have sperated the motherboard.
Now How to check the motherboard is the problem? I tried connecting just the motherboard with keyboard + powerboard and powered UP, but nothing was happening (no LEDs were blinking)I thought atleast if the CPU FAN run's then I can continue something.
Can I order the same motherboard and replace? please help me ...
  • vanantharama Jan 19, 2009
    if motherboard is the prob (short - heavy voltage) then it may affected the other boards like dvd drive expansion board or rear USB board or Express Card expansion board right? if I buy a mother board from ebay and if plug with these exisiting boards then it may again spail the new motherboard right? please advice me
    Sergeant:
    Champion:
  • 318 Answers
Look for the motherboard on ebay,,will be pretty cheap.
Posted on Jan 19, 2009
  • Alex M
    Alex M Jan 30, 2009
    It is possible that some other component may have an effect on the motherboard you install.
    But when you are buying used parts or replacing new parts with used parts ,it is alway's a risk.
My laptop keeps turning off by itself
can you tell more about the problem ?
if it turns on and enters the desktop and suddenly shutdown then it might be ventilation issue the cpu is over heating and the inner fans are either blocked by something or not functioning normaly if you put the laptop on your legs just don't because you are blocking the ventilation
Jun 02, 2012 | Computers & Internet
I'm having problem with my hp dv6000, the hp dv6000 is doing sudden shutdown once if i try to use it for long time it'll shutdown and after the first sutting down it will do like one,two or three...
Hello!
You can have software or hardware problem. First you must know what is temperature of you notebook. Sometime you need open the case and clean cooler.
Sometime the people slop the drink, and that can do problem on the motherboard.
You can also try another charger. Sometime you must format hard disk and make new system.
Jun 24, 2011 | Computers & Internet
LAPTOP does not turn on. only fan runs.
Things to check first.
1. Make sure you have a new BIOS battery installed. Some computers will not start if the battery for the BIOS is dead.
2. The CPU may have overheated and no longer works. I lost a CPU and everything was dead.
3. A dead motherboard can also act in like manner.
Sometimes something will come loose on the motherboard causing a direct short which of course fries the motherboard and probably the CPU. Dropping a laptop can shake things loose.
My Daughter had this happen with hers. It was a 800 dollar HP Compaq and I had a heatsink come loose on my HP Compaq which fried CPU AND Motherboard. Beware of HP since they bought Compaq.
Jan 25, 2011 | Intel Computers & Internet
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
One USB port outlet of my laptop is not working.
Mother board will have to be replaced to fix that problem. If you have other USB ports, you can buy a port replicator / hub to get more ports if you need them.
If you want to get the unit fixed, contact me for shipping information.
Jan 05, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
It shutdown suddenly while working
If Ur Laptop Shutdown While Working. Then First Check Out Your Bettery Life. If It is ok Then Make Sure Your Laptop Didn't Heat more. If Still You Face Problem Then Contact Hp Care No : 1800 112267.
Jul 29, 2009 | HP Pavilion TX2000Z Notebook
HP L2000 Sudden shutdown wont power up power supply good
what makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
Jul 17, 2017 | HP Special Edition L2000 LiveStrong Mobile...
HP Pavilion dv9207us DISPLAY PROBLEM [BLUE SCREEN PROBLEM]
safe mode roll back driver if cant roll back uninstall in safe mode, then deleting driver info, so it does not reinstall.
Oct 18, 2008 | HP Pavilion dv9207us PC Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Sudden Shutdown
bad capsisters on motherboard thx nick
Feb 10, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv9000z Notebook Logo
914 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
