Question about Sewing Machines
Singer touch and sew 648
My daughtee just got a singer touch and sew 648 and we don't have the manual. WE can't figure out how to thread the bobbin .
  • midnamoondog Apr 06, 2009
    I have a Singer model 648 sewing machine. My problem is that fabric does not get pushed through while sewing. Also I am trying to figure out how much this sewing machine is worth. Thank you for your help!
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Posted on Apr 16, 2010
When I fill the bobbin with thread, it doesn't load evenly and bobbin gets jammed.
When you wind a bobbin, the thread usually goes through a "feeder" which creates a tiny bit of tension and a lot of direction. Make sure you have it through this. It is usually two circular discs, cupped, and back to back.
Nov 21, 2016 | Sewing Machines
How to take out bobbin case from a Singer 648 sewing machine? The shaft of the bobbin case is broken.
It may be helpful if you can first remove the needleplate (pg 67). Here is an
Owner's Manual for your machine:
Singer 648 Instruction Manual
Feb 24, 2016 | Singer Sewing Machines
Singer touch & Sew machine model 648, the bobbin mechanism wont move all together. I need help!
The bobbin push button (button next to bobbin under the throat plate) must be in the sew position. When it is in the wind ( down to left) the machine will not sew. You need to push the button to the right to release it.
Apr 30, 2015 | Singer Sewing Machines
Thread a bobbin on a singer
have a singer model 648 self feed bobbin but with button pulled to left still wont thread bobbin
Jan 12, 2014 | Sewing Machines
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
How to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Jun 13, 2009 | Singer Sewing Machines
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Sewing Machines Logo
702 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
