Question about Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor
Husky pancake compressor won't fill
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Have you checked the ring and cylider or the valves?
Posted on Jan 04, 2013
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
What kind of oil do i put in my clark 4gal pancake compressor
If it's an oil-less, none. If it's a regular compressor, use compressor oil.
Jun 02, 2012 | Clarke Power Products Inc AC2001 2HP 4...
I have a husky 5gal. oilless pancake compressor it leaks air around outlet tube/hose rite at the pressure switch housing. How do you fix the line
You have to replace defective hose. Buy and fit a better / higher pressure range to prevent this condition. Check also all your hose connector for malfunction.
Regards
Apr 26, 2011 | Air Tools & Compressors
How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Dec 31, 2010 | Electric Air Tools & Compressors
The compressor fills and when it dipenses air and tries to refill it blows a fuse.
the outlet ur plugged into the amps are to low when compressor tries to restart under load which draws more power than what the circuit breaker is rated and or their are other things plugged in on same circuit drawing power and causing the higher amp draw-- plug into some other circuit preferably with nothing else plugged into the circuit or with a higher amp [20amp]breaker
Jan 22, 2010 | Campbell Hausfeld No.FP2028 Gal Pancake...
Husky pancake runs in reverse
I am a little confused here ... I have a Craftsman pancake, a Craftsman 6 hp (same compressor design) and several other name brand pancake compressors at the job. The compressor doesn't care which way the motor runs though mine all run in the same direction. As long as the piston goes up and down, the reed valves know when to open and when to closed based on the pressure. It sucks in from the 'room' on the down stroke and blows into the tank on the upstroke.
Yours isn't doing this? If it is creating a vacuum in the tank, I would have to say someone put the valves in upside down.
This is very curious.
You could reverse the black and white wire but as I understand the physics of it, it will not matter where the hot wire is since it is AC. The motor may be reversable but I'm thinking it is probably not in this case. That costs extra to make into the motor.
Please inspect the valves to make sure they are capable of 'inhaling' (the site will delete the other word I used) on the down stroke and 'exhaling' into the tank on the upstroke.
Please let me know what you find out.
Thanks for your curious question at FixYa.com
Jan 15, 2010 | Air Tools & Compressors
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor Logo
153 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
