Question about Apple iBook G3 Mac Notebook
I can't log in
My son has attempted to log into his account and it does not accept his password. I also have tried to log into my Administrator account and am unable to do so. It will not let us on. How can I get on this computer? I have restarted the computer several times, made sure the caps lock was not on, and checked the num lock is not affecting the password entry process. I am not sure how to get in to the computer to restart or do any troubleshooting. Any thoughts?
Thank you,
N.
  • 38 Answers
The password can be reset by booting from your OS X installer CD and choosing “Reset Password” from the Installer Menu.
Here a link to the Apple website that details how to do this.
http://support.apple.com/kb/HT1274
Posted on Feb 10, 2009
3 Suggested Answers
  • 159 Answers
SOURCE: Unable to log in.
You don't say what operating system you're using, but on the premise you're running one of the three last versions:
Posted on Jan 19, 2009
  • 13 Answers
SOURCE: unable to log in Windows XP
Hi
My name is Sydney, you should try to log in as administrator without entering the password that is if when installing the operating system the admin password was not set, in most cases when you switch on your computer the administrator use is not shown. So what you do is press ctrl+alt+del+del, you will have to hold ctrl+alt while you press delete twice. Then type under username administrator and on password leave it blank. if this does not work try entering your administrator password.
If this does not work, restart your computer. and go into safe mode, you can try to press F8, or F2 or Esc, depending on the make of your computer, this should be done before it shows the windows logo, at the time it is checking your drives.
in some cases you may have a problem with your keyboard, maybe some keys are sticking so you can try to use another keyboard and see if you get the same results.
if the above does not work, check to see if you computer has a recovery cd you can put this in your cd drive then restart the machine. it should ask you to press any key to boot from the cd, press any key then follow the on screen instructions. NOTE that with this process you may loose all you documents and your computer will restored to the way it was the first time you bought it.
I hope this solves your problem, but if the problem persists please do not hesitate to contact us again.
Kind regards
Sydney
My son changed his password on his netbook. now he doesn't remember it. he cannot log in at all. he can do absolutely nothing with it. how can we fix this?
at Windows XP's Welcome Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu where you can specify the User Name and Password. In the User Name text box, key in "Administrator" (without quotes) and leave the Password field blank. Then press Enter or click on OK. If there it is not a password protected Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Then simply click start > control panel > User accounts then select your sons account and click edit then click remove password. once done simply log off and then log in to your sons account and no password will be asked for. If your son is the root administrator then you will need to get software to reset the password for you
Mar 23, 2011 | Computers & Internet
Passord for home pc will not work what do i do to log in our home computer is a HP and my son set his password but now forgot it and we cannot log in on any users how do i get logged in without the startup...
Try to press Ctrl-Alt-Delete. The screen have to change and a dialog to appear with Username/Password.
Type "Administrator" (without the quotes) for username and leave password empty. Press Enter. If you can log in as administrator in that way, you can force set password for your user account in Control Panel/User Accounts
Aug 01, 2010 | HP w2558hc 25.5" Widescreen LCD Monitor
I brought the msi u100 series for my son he have forgotten his password so i need 2 no where we stick the recovery disk he had with it
Log on using the administrator account, the default password is none (blank) (in case you don't see the administrator account, at the log on screen hit ctrl+alt+del twice and at the new log on screen type administrator as user, leave blank the password and hit OK). After you have logged on you do what you wish.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 02, 2010 | MSI Wind U100-030US Laptop
Hi my Dell D420 it does not wont to accept the password how can I bypass and reset the password please ?
You mean the windows log on pass? Which version of windows do you have? Try logging in at the administrator account (the default pass is blank).
Stelios.
Feb 21, 2010 | Dell Latitude D620 Notebook
Trying to login to my account,it's not accepting my login,or anything
If you mean trying to log in to your computer using your Username and Password then I suggest trying to log in to the Administrator account and change your passowrd for the account you are unable to log in to
Once you are in the administrators account, check that there are no limitations on your account that prohibits you from logging in. To do this right click on My Computer and click Manage. On the computer management window click on Local Users and Groups, click on Users folder.
Where your username is right click and click on Properties. Make sure none of the boxes are ticked (especially Account is disabled - If it is untick) and tick Password never expires and click on Apply
Log out of Administrator Account and log in to your own
Oct 22, 2009 | Computers & Internet
L cant log inwont accept my password this only happened yesterday 6 4 09
if you are talking about a log on password..(into your computer ) it means that somebody either changed you password..or you forget it ...also try to see if the caps-lock isnt on ....if you have a guest account ...just ask the one with the administrator account to delete that account ...but save personal files..into a folder and make another on e..
if it is an administrator account ...and its the only one ..the options are limmitated if the password wont work ...you try to remove the bios battery to delete any password might be there ...and in the last to reinstall ( repair ) the windows...you can do that without loosing any data ..by reinstall windows in the same folder without formating the partition ...Good luck !
Apr 07, 2009 | Dell Inspiron 8600 Notebook
Acer Aspire M1100 Desktop - lost password, can't login in User Login. Is there a way to bypass the password?
If you're having trouble logging into Windows, you can attempt to use the Administrator account to edit/remove the password of the user login. The Administrator account is hidden by default while in normal mode. You'll need to boot the PC into Safe Mode and login as the Administrator account. Follow the below steps:
  1. Reboot the PC and before the Windows boot screen appears, tap the F8 key about once per second.
  2. Eventually you'll be faced with a screen asking you how you want to boot Windows. Select Safe Mode.
  3. You will see some dll, sys, and com files scrolling down your screen, this is normal. Eventually the PC will boot up and you'll have a login screen with your User Account(s) and a new account, Administrator. Select Administrator.
  4. As long as you haven't, in the past, altered the password for the Administrator account, you should be able to simply click this account and have it log you in. If it requests a password, you might try "password" (without quotes) for the password.
  5. Once in, Navigate to Start -> Control Panel -> User Accounts
  6. Select the User Login information that you're not able to log into and remove the password for the account or change it something you know.
You can now reboot the PC normally and be able to log into this account without a password or with the password you created.
Mar 05, 2009 | Acer Aspire™ T180 PC Desktop
Unable to log in.
Jan 19, 2009 | Apple iBook G3 Mac Notebook
New account change/cannot get it to accept my password
To make any changes, you must first be logged in as administrator. Once you make the changes, you can log into the new account you created. In other words, you will create the new account while you are logged in as administrator. Hope this helps.
Mar 17, 2008 | Computers & Internet
Apple iBook G3 Mac Notebook Logo
183 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
