Question about Soleus 12,500 BTU EverGreen Products Packaged Terminal Air Conditioner
Soleus 12,500 BTU EverGreen heat pump - Soleus 12,500 BTU EverGreen Products Packaged Terminal Air Conditioner
4 Suggested Answers
  • 5 Answers
SOURCE: soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
Posted on Jul 09, 2010
  • 5 Answers
SOURCE: Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
  • 6 Answers
SOURCE: would you know where to purchase a condenser fan motor capacitor for the 18,000 Btu Soleus Air Mini Split Air Conditioner + Heat Pump
AireCo, United Refrigeration, online, electric motor shop.
Posted on Aug 10, 2012
What does F2 error mean?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2016 | Soleus KFHHP18 18,000 BTU Single Zone...
How do i get this to the heat setting ?
Hello there.
If you have the right model of this machine
Press 'mode' switch as per page 9 of user guide here
http://www.soleusair.com/Manuals/2014%20B%20manuals/SG-PAC-12E1%2012E1HP%20manual%2010052012.pdf
Also can do it on the 'remote control' if you have it.
Sep 16, 2014 | Soleus Heating & Cooling
Display is out
Push the swing button 2 times quickly. This will turn the display back on.
Jan 15, 2014 | Soleus Air KFHHP-12 12000 BTU Mini Split...
Newly installed, the outside unit will not run but the fan on inside will run
checkto see if your getting 24voltsat the condensers control wire and chech for power voltage
Jan 08, 2013 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
Why do i have to empty the water out every 2 hours 14000 btu portable plus humidifier aitconditioner 14200 btu heat pump
That is normal for a portable a/c unit if it has a drain on it you can put it on a shelf or counter and allow it to drain to a floor drain or sink. some newer units come with a pump to remove the condensate, this is the water you normaly see driping out of the a/c units in windows
Jul 21, 2011 | Soleus Heating & Cooling
Hi
Problem solved!
Jun 17, 2010 | Soleus LX-140 Portable Air Conditioner
Soleus 12,500 BTU EverGreen Products Packaged Terminal Air Conditioner Logo
18 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
