Question about Viking 37 in. DGCU165 Gas Cooktop
Viking range dgcu165 long wait for gas to flow after knob turn
This range after sitting for 20 mins or maybe 30, has no gas flow when you first turn any knob. The ignitors spark fine until ignition, it's just that the 1st time you turn the range on after sitting a while, no gas flows for 5-6 seconds. Then you hear the gas come on and then it lights. After that, it releases gas no problem immediately, until you leave it alone for 20-30 mins.
  • newcrossroad Jan 19, 2009
    Could you detail that procedure for me, in general, and a description of the assembly? Thank you!
    Oh wait, how does the ignitor assembly control the gas valve? I cannot hear gas flow until 5-6 seconds after the knob is turned, then it ignites. This does not occur on the second or multiple later tries unless the range is left to sit unused for 20-30 mins.
  • 334 Answers
The ignitor assembly/s need to be cleaned.
Posted on Jan 19, 2009
  • Danny Clark
    Danny Clark Jan 19, 2009
    A dirty/clogged ignitor assembly will cause the initial low volume gas flow for ignition to fail to ignite. It then ignites when the gas builds up enough to get past the restriction to the ignitor.
My DGSU100-4BSS-LP Gas Cooktop spaks but does not ignite
Check for LP leak. You also have to wait for air locks to vent out through burners to get lite the first time.
Jul 29, 2012 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
When i use one burner the other one makes the electrical pop
That allows you to light that burenr turn the knob to mid range for the gas on both or full on and it should stop. there is one igniter and 4 burners. Each burer controls the igniter when oven calls for gas.
Aug 29, 2009 | Viking Cooktops
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
VGSU 36" gas cook-top control panel paint coming off
I just bought a bank repo home in So. Cal. that has the same Viking range as you have. Yes, the black lettering has almost entirely rubbed off. on this one too. Not good for such an expensive product.
I bit the bullet and ordered a new panel from appliancezone.com
http://store.appliancezone.com
Part # PE40057
The price is about $75, $80 with shipping, which is a ripoff I know.
I plan to put a clear coat of sealer on it and let my wife know to treat it gently.
I was surprised how many people think Viking products suck. Lots of negative reviews abound on the internet. If I was to buy a whole new range I think I'd avoid this brand.
Cheers,
Andy Dale
Apr 22, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Gas is flowing to all, but the front left burner will not ignite.
hello, it sounds like your Spark switch went out its located just under you knob to check it you'll have to open the top of your range and look at the one for your bad burner and see if thairs any burn or black marks on it that'll be a dead give away to it being bad or going out, what probably happened is that the water caused a ground and burnt it out. if that's the case and you need to order a new one here's a web sight were you can order the part from all you have to do is put in your ranges part # and click on the things on the left side of the page to find the exact part for your appliance.
http://www.repairclinic.com/
Mar 29, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
May 18, 2007 | GE 30 in. JGP337 Gas Cooktop
Viking 37 in. DGCU165 Gas Cooktop Logo
199 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
meztang
meztang
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
