Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
My frigidaire dyer comes on then the pause message appears. These are new appliances.
  • Official Brand Answer
  • 4,342 Answers
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Posted on Jan 06, 2013
When i try turn my frigidaire affinity dryer on it buzzes and goes to pause
Good Morning friend, thank you for your post!
From the information you have provided your Frigidaire dryer is buzzing and goes on pause when you attempt to turn it on. This could be a possible issue with your door latch, door strike, or control panel. If you dryer shows pause that means there is an interruption within your cycle. I would advise to look over your door latch and strike to see if there is any apparent damage to either component. If both components appear to be working properly I would advise to have a technician come out to review your control panel. I hope this information has been helpful to some degree. -Matt
Feb 17, 2015 | Frigidaire Dryers
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Why does it keep pausing during cycle?
Hello friend, thank you for the post!
I understand that your Frigidaire washer, ATF6000es, keeps pausing during a cycle. Generally that means there is a disruption in the cycle. I would try resetting your appliance, unplug the power cord or flip the household circuit breaker, for ten minutes. If that does not resolve the issue it could be a problem with your control board or wiring harness within the washer. I would recommend having a technician come out to the home to diagnose and repair the appliance. Hope this is helpful. -Matt
Jul 31, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer pauses during wash
Good Morning Friend,
I understand your Frigidaire washer, model# GLTF2940ES, is pausing during the wash. There could be a miscommunication between the different boards inside your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is making my Frigidaire Affinity Washer FAFW3801LW fill and start working and then after 2 minutes there is an ugly noise and it displays "pause"?
Good Morning Doina,
I understand your Frigidaire Affinity washer, model# FAFW3801LW, will fill and start working. I also see that after about 2 minutes, you hear an ugly noise and your appliance displays "pause". I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FAFW3801LW Washer
Pause comes on after it starts secing
I understand that the pause comes on, after starting your Frigidaire washer, model# ATF6000ES. I please ask that you try resetting your appliance, by either unplugging it or shutting it off at your home's circuit breaker, for 3-5 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire ATF6000ES Front Load Washer
FRIGIDAIRE FAFS4474L IS PAUSE
Hello Radwan, thank you for allowing me to assist you! Error code "PAU" usually means that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit on. If the issue persists, then the appliance could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Aug 28, 2013 | Frigidaire Affinity FAFW3511K Washer
Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
281 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
