Question about Gateway M-6750 Notebook
M6750 lcd whiteout
Vista works when laptop is connected to another monitor but laptop screen is white when used. do i need a new lcd?
  • 2,404 Answers
Its going to need to be troubleshot deeper. Its either going to be an lcd, inverter or a motherboard problem. The only thing to do is to try another lcd and inverter. If those fail, then it has to be the lcd connector on the motherboard which means the motherboard would have to be replaced.
Posted on Jun 10, 2009
Laptop white screen
Having a laptop screen turn white is one of the most frustrating problems a user can experience since it prevents use of the laptop to find a solution.
A white laptop screen indicates a serious problem with the laptop's hardware, and no easy solution to this issue exists.
Just diagnosing this condition requires advanced computer knowledge.
Identification
With this problem, the laptop itself will power on and load the operating system as per usual, but the screen will become a complete, static white, according to LaptopRepair101.
No particular brand or make of laptop falls prey to this issue more than any other; it can happen to any laptop.
Causes
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop.
The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard.
The issue can also reside strictly with the motherboard or the screen might contain a defect.
Considerations Users can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists.
Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
Motherboard Problems
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop.
This requires the user connect the inverter board--the power supply for the LCD backlight and the video cable to the test LCD.
If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Prevention/Solution
Taking apart a laptop screen may make some users feel uncomfortable, so you can use an external monitor connected to the VGA port common to most laptops if the processor and hard drive still work fine. Using an external monitor requires finding the proper function key command to toggle between the LCD and external monitor.
Warning
Taking apart the LCD screen on a monitor likely voids any manufacturer's warranty.
Consider visually checking the video connection to the laptop screen as a last resort if no other viable options exists.
The service manual that came with your laptop likely offers some tips to disassembling the computer, or conditions that could void the warranty.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Jul 02, 2013 | Dell Inspiron Computers & Internet
How would the pattern on the screen change if a pure blue screen were substituted for the white screen?
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 31, 2013 | Computers & Internet
White screen
Jan 31, 2013 | ASUS Computers & Internet
My acer laptop show white sceern only?
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope it helps
Jan 23, 2013 | Computers & Internet
I only have a white screen,connect to another moniter still no screen.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
For more information:
http://solvetheproblemhere.blogspot.com/2011/05/laptop-lcd-screen-turned-white.html
May 10, 2011 | Samsung N150 Notebook
When i power on the laptop nx 6110 it brings a white screen on the LCD.
May 09, 2011 | Compaq NX6110 TFT XGA Notebook
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
It’s possible that you have to use a different key combination on your laptop but you get the idea.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
Feb 01, 2010 | Computers & Internet
The display turn white >>>what can i do?
CONCLUSION.
Jan 18, 2010 | Samsung NC10-14GW Notebook
When I turn on the computer the screen is white but the computer is booting up.
CONCLUSION.
Jan 14, 2010 | Dell Studio 17 Laptop
White screen
If its your laptop's own screen that's going white its a known issue with the old Presarios and Armada laptops that their graphics boards or connectors wear out and eventually lead to "Whiteouts". Take it to a HP repair centre if possible, they can quote for repair. It might just b be the graphics cable needs reseating in whcih case it would be quite cheap to fix. If you you need a replacement graphics board it will be quite expensive and possibly not economical to repair.
If you mean an external monitor then once you have confirmed its not a loose cable or a pin broken at one end then the monitor itself is probably faulty.
May 17, 2009 | Star Logic 17" LCD Monitor
Gateway M-6750 Notebook Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
