Question about Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 685 Ice Maker Problems
Had a service guy come out to tell me that Ice Maker needed to be replaced. Dual valves were also recently replaced. Water was leaking into the Ice Chest and freezing the ice as well as pooling on the bottom and eventually freezing. I purchased an Ice Maker online and replaced, but seems to be doing the same thing. I adjusted the water fill as well w/ no success. Is there something wrong w/ the timing at which the ice is released ? Please advise.. Thank You.
  • minszero Nov 17, 2007
    My icemaker isn't making ice. Everything seems to work, but I don't ever hear any water running thru to make ice. Yet, the water dispenser works on the door. What should I be looking for?
  • 175 Answers
There are 2 important things to be aware of with these icemakers. One is that they need to be completly level, both side to side and front to back. Second, the fill on these icemakers should be right about 100 milliliters. Get a measuring cup with Ml markings and pull out the icemaker. Fast forward the icemaker by jumpering the little test terminals behind the square cover. You need to connect the terminals labeled T for thermostat and H for heater together with a piece of wire. Be careful, as there is 110 volts to these terminals. Keep the wire there for about fifteen seconds,then pul it out or the icemaker will get really hot. Just as a note, for all this to work the icemaker must be plugged in, turned on , and you must hold down the switch that is pushed by the bucket. If there are no test terminals on the icemaker, then you can just fast forward it by pushing the fingers around in a clockwise direction looking at it from the square end. Anyways, once you get it moving, put your measuring cup under the fill tube and wait for the fill cycle. the water should be very close to 100 ml (range is 90-120ml). If your fill is correct, and the icemaker is PERFECTLY level, then make sure the fill tube is inserted all the way into the icemaker. Hope you can wade through all this for an answer. Good Luck!
Posted on Jun 27, 2007
WATER DOESNT SHUT OFF AFTER ICE CUBES ARE MADE- THEN THE CUBES BECOME ONE SOLID BLOCK FROM THE DRIPPING WATER. SERVICE GUY SAID NEED TO REPLACE THE ICE CUBE MAKER: STRANGE THE ICE CUBES ARE PERFECT -...
Replace the water inlet valve to the unit. The valve is not closing completely after the water is called for. By replacing the valve should solve this issue.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 12, 2013 | Sub-Zero Refrigerators
Ice maker stopped making ice
If ice maker is not filling with water then fill with tap water and allow to freeze. If ice maker cycles and then does not refill then this points to water control valve. If that happens replace water control valve. Ifice maker does nothing but freeze water to ice then the ice maker will need replaced or parts causing problem fixed. Please call Sub Zero at 1-800-222-7820 and they will refer you to one of their six authorized parts and service centers. Thank You, Sea Breeze
Nov 24, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
Ice maker not working. I have already replaced the water valve. What's next?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
99086908
Apr 10, 2010 | Sub-Zero 650 / O Bottom Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Sub-Zero 690 Side by Side Refrigerator Logo
506 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
