Question about Acer Aspire (AST180-US340B) PC Desktop
Computer wont boot hear one beep from motherboard over and over
Acer AST 180-UA350B Aspire wont boot.power outage last night computer was turned on . Went to use tonight found it would turn the cpu cooler fan for a second or two, then turn off fan and start beeping one long tone over and over.
  • 3 Answers
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
I can i do if my computer start but no one view in my monitor but still my cpu on.
Posted on Feb 19, 2009
  • 32 Answers
Seems there is poblem in your Smps , you are requested to cntact to your vendor for the  same.
Posted on Feb 11, 2009
  • 79 Answers
Looks like you got a power surge. Did you have it plug in on a power surge? It might sound like one long beep but really it could be many beeps. It beeps really quick. If you listen carefully you can count the beeps. Repost it here again how many beeps you got. Right now I'm thinking your motherboard or your cpu is broken
Posted on Jan 19, 2009
    Scholar:
  • 88 Answers
It sounds like you might have burned out the power supply on your PC with a power surge when the power came back on. The are fairly inexpensive and some what easy to replace.
You will want to replace it with one of equal or greater watts. You can order a new power supply on line from many vendors.
I would not be turning the computer on and off any more. I would unplug the computer, remove the old power supply and get a new one.
You should have your system plugged into a surge protection power strip if possible.
I hope this helps,
Eric
    President:
  • 2,692 Answers
Acer aspire l3600
You may have a bad power supply. Did you turn it off, or did it go off by itself? Do you hear any beeps when you try to turn it on? Those may help you figure it out. If nothing happens you need more help, like a technician in person.This may be simply the power supply, or the motherboard may be done for.
Jul 19, 2013 | Computers & Internet
Battery light just flashes on acer aspire 5155 no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 04, 2012 | Acer Computers & Internet
Can't get the side panel off my acer aspire ast 180-UD360A
Hi I was suppose to provide you the instruction however it would be better if you will see the images including steps on how to remove the side panel of your tower..This website will help you a lot ..
http://global-download.acer.com/Step5.aspx?Step1=Desktop&Step2=Aspire&Step3=Aspire%20T180&BC=Acer&Category=Document
Nov 17, 2011 | Acer Aspire™ T180 PC Desktop
Acer Aspire T 180 stops with Acer Logo
What you were trying to do tried to remove the RAM and boot your pc. Buddy once you remove your RAM you are going to get long beeps as it tells there is no RAM on mother board and it won't boot. Just install back all the things and let me know how many beeps you are getting and what type short and long.
Feb 22, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Looking for manual for acer aspire m1201. its on complete lock up powers up and thats it
Please go thru this link to find the manual.
http://support.acer.com/us/en/acerpanam/desktop/0000/Acer/AspireM1200/AspireM1200nv.shtml?Team=%2Fus%2Fen%2Facerpanam%2Fdesktop%2F0000%2FAcer%2FAspireM1200%2FAspireM1200nv.shtml
Feb 07, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I have an ACER Aspire AST 180-UD360A. Was working fine till yesterday. Turned it on and Acer logo came on with "enter setup F12" then went black - dead. Computer does not turn on at all. Checked power...
From what you describe, you issue could well be the hard drive. Turn the system on, then press f12 to enter the setup, see if the system stays running. While there, if it stays on, see if the hard drive is detected.
If the HDD is detected, see if you can run diags on the drive.
Other options, boot to the Windows Media and see if the system stays running there. (you may have to remove the hard drive to do this)
If the system runs in any of these and will not boot to the hard drive at all, then there is a good possibility that the drive is bad, and you may well have lost your data.
If the system continues to power off, even with the HDD removed, then the motherboard is likely the failure.
I
Jan 12, 2010 | Acer Aspire (AST180-US340B) PC Desktop
My Acer Aspire T180 won't boot
There is one thing you can try first before replacing *********** board.
Try shorting the jumpers on the CMOS battery. look for the JP3 jumper usually it is near the battery it looks like a quarter coin only a little bit smaller. If your having difficulty finding the jumper remove the battery for 24hrs. this will reset the CMOS then put it back in and power on the CPU.
If that doesn't work then replace *********** board is easy. bring it to a computer shop so they can match the devices in your CPU to match a motherboard of your choice.
Aug 04, 2009 | Computers & Internet
My Acer Aspire 180 ast power light flashes 4 times when I try to start it but it doesn't power up. I've unplugged the power and plugged it back. Can hear the fan start when I plug it back but it still...
Could be a faulty power supply or maybe motherboard problem.But I would open the case and clean the processor fan first as it could be a heat issue preventing start up.
Aug 01, 2009 | Acer Aspire™ T180 PC Desktop
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire  (AST180-US340B) PC Desktop Logo
1,215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
