Question about Frigidaire FRS26F4C Side by Side Refrigerator
Evaporator frosted on top only and both fridge and freezer are cool not cold. I had to throw away food from freezer. I removed panel and defrosted the evaporator and let run for 12 hours and again evaporator was froze at top only.
  • Chuck Reed Jan 04, 2013
    after posting this issue i have with the freezer. I have had the freezer side empty and now i will not stop running. My wife put a bowl of water in the freezer and it froze within 8 hoursbut i am unable to get it to shut off and the refigerator still not staying cold without having the temp dial set to max. We have had the fridg for 6 years now and it worked fine until the holiday. A nother thing is the ice maker will not make ice as well. Thanks for you time on tryig to help
  • Official Brand Answer
  • 4,342 Answers
Hello Chuck Reed - Sounds like the refrigerator has a sealed system issue or the defrost circuit is not completing properly. I strongly suggest contacting a professional to move forward accurately.
Posted on Jan 09, 2013
  • 183 Answers
SOURCE: Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Posted on Aug 21, 2007
the dr
  • 447 Answers
SOURCE: Fridge not cooling compressor works intermitently
Is the brand name of the compressor Tecumseh?? How old is this fridge??
Posted on Jan 10, 2008
SOURCE: FRS24zrh Side by Side Fridge was
I had the same sort of problem. Found that the freezer would not completely defrost on each defrost cycle. Replaced the defrost thermostat and solved the problem.
Hope this helps.
Posted on Aug 06, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
freetek
  • 5568 Answers
SOURCE: it is actually FRT21INLHW4, but i can find no
The cooling coils are normally located around the freezer with the refrigerator being cooled via cold air circulating from the freezer to the refrigerator. If that concealed fan has failed, the mere fact that cold air falls might explain why the lower compartment is getting the hog's share of the cooling.
You should be able to see vents in the rear of the fridge; hold your hand (wet might be better) in front of those vents. You should be able to feel a flow of air into the fridge. If you don't, the fan may have failed.
Try Sears parts section to see if your unit is listed; they often have repair parts for many brands and models, and even more important, an illustration of your model which could guide you on how to access the fan for replacement.
Another possibility is the failure of the defrost timer that controls a heating coil also located near the freezer. If your defrost heater is staying on because the timer has failed, it could cause the situation you have. The timer is often located behind the grill at the bottom of the unit. Some of them have a **** to turn the timer mechanism manually. You can mark the protruding shaft position with a piece of tape or white-out to monitor if it is still running at all.
With the grill removed, try to remove as much of the dust bunnies from the coils as possible since this prevents the lower fan from getting air onto the coils to disperse the heat from the coils.
Posted on Oct 08, 2009
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
My refrigerator is not keeping my food cold or frozen!!
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 24, 2009 | Kenmore Refrigerators
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
GE SIDE BY SIDE FRIDGE FREEZER
Need more info on this whats is beeping? do you have any error codes, when is was plugged in... was ALL the fans blowing.. freezer fan and fan below by compressor? was there any frost on the back wall of freezer?
Aug 31, 2007 | Refrigerators
Refrigerator does not get cold
ou need to check to make sure the evaporator fan is working. If it is remove the freezer back to look at the evaporator to make sure it is not frozen over. If it is you have a defrost problem. when the coils on the evaporator get all frosted over air can not move over the coils for the fan to circulate the air through out the compartments so the fresh food section will get warmer while the freezer will be cold. you will need to defrost the evaporator to be able to check the treminator and the heater. to do that you will need to turn the timer thats is located in the fresh foo section usually in back of the thermostat. there may be a removable plug to expose the dial to turn it manually. use a flat blade screw drier to do that. it will only turn one way. as soon as you hear a click stop. the compressor and evaporator fan should stop running. now you can check to see if the heater will come on. if not you will need a volt meter to check the terninator heater and to make sure the defrost timer is all good. you should have 120v at the heater. if you do ohm out the heater to make sure it is ok. most times if it is a defrost problem check the terminator first thats the round disk with 2 wires on it. if it is not closed the heater will not come on.check it out and you should find if there is a problem with the defrost cycle. if you turn the timer untill you hear it click again and the fan and compressor should be running. when you remove the freezer cover and you find the coils are only frosted at the top or just a verry little, you may have a leak in the sealed system and that would be why there os por cooling. you would need to call for service if that is the case. hope this help you some
Aug 10, 2007 | Frigidaire FRT17G4B Top Freezer...
Frigidaire FRS26F4C Side by Side Refrigerator Logo
288 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
