Question about Franklin BATH UNLIMITED RESIDENTIAL GRAB BAR
Remove rust from bathtub grab bar - Franklin BATH UNLIMITED RESIDENTIAL GRAB BAR
2 Suggested Answers
  • 4 Answers
SOURCE: shower grab bar has rusted
u could always repair the rod, its cheaper and easier, first of clean the rust off with viniger, white works best, then go buy some enamel paint, a small jar of whatever colour it is make sure its water prof, i suggest u do this in the morning then it will be dry for u to use at night, and there u go, if ur lazy however spend the money and change the bar, gd luck!
Posted on Apr 12, 2009
Bathtub clogged. has a screw down drain cover and three under the drain things that hold the drain in. How di I take the cover off.
You may need to get a small punch and hammer or a chisel and hammer and tap on the screw holding down the cover in a counter clock wise direction until the screw is high enough you can get a pair of vice grips on it and finish removing it from the cover.
Nov 19, 2012 | American Standard Cambridge 5' Americast...
How do you remove the cover plates on a delta grab bar
Look at it carefully. There could be a set screw or a very small notch where you take a thin flat head screwdriver and pop it off.
Apr 21, 2011 | Home
Americast tub has a scratch
try rubbing some toothpaste over the scratch with your finger you will be amazed
May 08, 2010 | American Standard Cambridge 5' Americast...
How do I fix a leaky faucet?
change the washers or if it is a flick mixer type the cartridge will need replacing
Mar 31, 2010 | American Standard Cambridge 5' Americast...
Bathtub chips
To fix small porcelain bathtub chips, you can use acrylic nail polish that matches the bathtub color. Just get some fine sand paper to remove any rust, then clean with alcohol, let it dry, and then touch up with the nail polish. Use a hair dryer on high heat to help dry faster, but wait several hours after to use.
Jan 14, 2010 | American Standard Cambridge 5' Americast...
Slow drain in the bathtub, cannot use a snake because the drain hole has an old metal piece that is divided into 3 spaces.
Be best to use a chemical drain unblocker, Mr Muscle or similar. Possible Caustic Soda. Usually all the hair and grime clog up, chemical unblockers usually do a good job of removing this.
Jan 10, 2010 | American Standard Cambridge 5' Americast...
Tub has huge dip in center
yes, thats for you to sit in!!!!!!! dont 4get to fill it up with water first!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Nov 20, 2009 | American Standard Cambridge 5' Americast...
Shower grab bar has rusted
Apr 12, 2009 | Franklin BATH UNLIMITED RESIDENTIAL GRAB...
Thread getting stuck
We had he same problem with no solutions posted. Solution: First, make sure the bobbin case is clean. Ours was slightly rusted. The rust acted like a fine sand paper keeping the thread from encircling the bobbin. We used an metal cleaning powder to remove it. we also noticed that the entire bobbin area of the machine was dirty and had oxidation on the metal. We cleaned that as well.
Second, we checked the hook's action. (We took off the ring around the bobbin and removed the bobbin case as well. we left the hook in the machine and then turned the machine. We watched for how well the hook grabbed the thread from the needle.) We noticed that the hook was slightly slow and was not grabbing the thread. The hole in the needle was slightly above the hook as the needle retreated and hook spun around.
To repair this, we took off the front plastic cover (the side facing the operator). There are screws on both sides of the machine for this. After the cover is removed, you will notice a flat bar going from top to bottom about 1/3 from the right of the machine. This bar has four screws. This bar is the timing adjustment for the bobbin hook. Loosen all four screws. If you turn the bobbin by hand, you will see the bar flex back and forth. Turn the bobbin all the way to the right and tighten the screws. The hook should now catch the thread properly.
Aug 25, 2008 | Brother LS-1217 Mechanical Sewing Machine
Franklin BATH UNLIMITED RESIDENTIAL GRAB BAR Logo
56 people viewed this question
Top Franklin Home Experts
Donni Steen
Tom Chichester
Are you a Franklin Home Expert? Answer questions, earn points and help others
