Tv keeps going into standby at random times, sometimes after half hour, then 2mins
Randomly goes to standby, I turn it back on light flashes bout 6x then get picture, then could be on for half hour or 2mins and will do again. No timers are set and are turned off. Tried unplugging it and the usual tricks..... At a loss!
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
What is the Brand name and Model number to your TV?
Posted on Jan 03, 2013
  • Claire Jan 04, 2013
    It's a bush led HDTV, think I pressed wrong button earlier, will look for model number
  • Claire Jan 05, 2013
    Sorry i think i may have pressed report abuse for your reply previously, that was not intentional, sorry. The model number is:LED26982HDT. Kind Regards claire
cyberclash
  • 6 Answers
SOURCE: blinking stand by light
the cause of your problem is in the crt socket your tube may be weak.try to adjust the g2
Posted on Jun 25, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
yambo
  • 230 Answers
SOURCE: standby light just flashes when power is turned on
Look, your tv is in Loose connection,, A lot!. Common problem on sony tv. OPen tv , resolder all ground area ( beside fly back ) and you will see again your tv !!!
Posted on May 11, 2008
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
jerryg50
  • 1673 Answers
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
Samsung LN 32C 530F1F keeps powering off randomly
probably overheating. hoover out the vents and make sure plenty of air can circulate. a case of suck it and see. lol
May 24, 2017 | Zenith Televison & Video
The TV was working, and then randomly just shut off and won't come back on. It still makes the click noise when i turn it on, but only once instead of two. The standby light keeps flashing four times....
Hello melanie Hi, in my experience as a TV technician, that would usually be a shorted part, the horizontal output transistor, that part powers the HIGH Voltage section. Very Lethal, the power supply detects this bad part which in turn makes the unit go in standby so as not to damage the TV much further. mMy advice is go seek a tv tech to repair the part.
Jan 20, 2011 | Sony KV-27S42 27" TV
Samsung 2006 56" HLR5688W DLP TV Right half of screen turns black. Left side normal picture. Corrects itself when set is turned off and back on. Randomly occurs - sometime picture is ok for half a day...
Possibly a bad light tunnel assembly if the part is only a shadow effect. If not then probably a bad DMD board. The DMD board is part of the light engine but needs to be replaced by a technician.
Aug 15, 2009 | Samsung Televison & Video
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
My Truck honks 1 time randomly when alarm is activated
This is a factory system? don't remember any LED in a factory system.
Nov 25, 2008 | 2004 Ford F150
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
