Question about Whirlpool Ovens
Whirlpool AKP262/IX oven showing ---c on display clock what does this mean
  • 1 more comment
  • Costas Vlachos
    Costas Vlachos Oct 20, 2015
    Do you know the answer? i have the same issue
  • Kirsty Young
    Kirsty Young Jul 11, 2016
    i have this issue does anyone know how to fix it x
  • Kirsty Young
jmgldsmth
  • 1889 Answers
SOURCE: i have a whirlpool builr in microwave oven and oven
it means "door open" the door switch is not closing
Posted on Apr 22, 2009
  • 18 Answers
SOURCE: Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
Posted on May 17, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool AKZ146/IX Oven Shutting off and
You have a burnt,broken or loose wire in there somewhere...finding it can be a real chore...in fact the only way you may find it will be to use an electrical meter and trace the power...even then it can be time consuming and difficult...
This type of problem often comes from using the "self cleaning" feature on your oven and often happens right after using it, as that is when the wires get too hot and burn.....
It also happens with age as the wires heat and cool and then the terminals start to loosen up and no longer make good contact....
You can sometimes find the loose wire by moving them around while the power is on, but this can be extremely dangerous!!!
Heatman101
Posted on Jun 20, 2011
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool Double Oven Model GBD307PDS09
Hello, welcome to FixYa.
I understand based on your post you have the Whirlpool GBD307PDS09 double oven with the "fading display" scenario, correct ?
The issue with these displays is they can lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to rebuild the control/display kit...the display only is not available.
**For the display/timer your only option (the only one I'm aware of)... it's the one I recommend as opposed to replacing the entire unit, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link's I've provided below. The first is the Whirlpool visitors site, the second is a list of timer numbers they do (yours is 8302319)
http://www.corecentricsolutions.com/published/whirlpoolappliancepartsrepair
http://www.corecentricsolutions.com/WP_Parts_List.html
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2011
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
This is an oven model Whirlpool AKP 262/1X. An error code ---C has appear on display. Can you please tell me what it is an how to fix if simple to do?
Aaron Crawford, we're sorry to learn of your concern. We recommend contacting our counterparts in your Region for assistance due to you are located outside the US.
Sep 05, 2015 | Whirlpool Ovens
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
My oven..whirlpool model...has F1 in the display window. What does this mean?
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
Solve it with replace electronic oven control (also called EOC or clock).
Hope helps.
May 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
1,027 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
