Question about Panasonic Lands Phones
Kx ts500mxb one of the buttons (no.7) is not working
I need sample & rate of Panasonic Telephone (Model no. KX-TS500 MXB)
Posted on May 13, 2014
Where can I get a driver for a dot matrix printer KX-P1150 I am using windows 7
There are no Panasonic driver that will work , however Use EPSON
FX Series 1(80) INBOX Driver*1 instead. It will work a treat!
Cheers,
John
Oct 20, 2014 | Panasonic Kx-p1150 Kx-p1150 Dot Matrix Pr
Panasonic KX-FL511 The 7, 8, & 9 buttons on the phone dial pad and the 'copy start' button have stopped working. All other functions and buttons work fine, what do you think it is? and how can it be...
The signal from each of these buttons, as well as the Prev and CID Print buttons, goes to the same place: pin #1 on the little square chip that controls the keyboard and the display. Suspect either the chip or that section of wiring. This is all on the operation board (the one on which the switches are mounted). The machine can be repaired by repairing or replacing the operation board. If you are an electronics tech or do-it-yourselfer, see the instructions and parts list in the service manual. Otherwise, you can search for a tech in your zipcode at the bottom of this Panasonic support page. Insert mode
Mar 29, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
I installed a caller id card in my kx-ta624 panasonic system in my home. The manual I have describes kx-t7030 phones with a caller id indication button but my phones kx-t7730 do not have a button and so I...
You get to program it :-)
In the User's manual section 2-2 there's an alpabetic index for Caller-ID. It requires 2 buttons, a CID-Indicator and a CID-Select button. We usually put them as the top 2 buttons in a 773x series phone, but you'll have to pick 2 adjacent or similar CO buttons. You label them CID-I and CID-S. Then you program them for either 96 and 97 or 6 and 7. You also have to tell the programming that you are setting up the common CID if you use 96&7.
Carl
Dec 12, 2010 | Panasonic KX-T7730 Corded Phone
I need drivers Panasonic KX-FLB758 for windows 7 please... thank I´m from Argentina
KX-FLB758 was apparently a clone of KX-FLB756 and KX-FLB751 model. Drivers available on the following page should work fine:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/Drivers-Downloads/model.KX-FLB756.D#ts
Aug 19, 2010 | Panasonic KX-FLB756 Plain Paper Laser Fax
I need to change the time on my clock - Panasonic KX-T7730
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set.
1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000
4.- Press "SPEAKER" button
5.- Press "FORWARD/DND" button to change to the hour selection
6.- Press "TRANSFER" button and enter the hour
7.- Press "FORWARD/DND" button to change to the minutes parameter
8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter
10 Press "MUTE" button to select AM or PM
11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed)
12.- Press "HOLD" button
13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7730 Corded Phone
Simplify the changing of the timeon the Panasonic phone KX-T7731
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming2.gif mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7731 Corded Phone
Need usb driver for KX-FLB802
http://panasonic.net/pcc/support/fax/europe/model/model_europe.htm
i was told the if you used the vista drivers with out installer you can get it to work on windows 7
Sep 25, 2009 | Panasonic KX-FLB801 All-In-One Laser...
How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
Sep 22, 2008 | Panasonic KX-T7730 Corded Phone
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Lands Phones Logo
57 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
