Have a brand new cannon mx 172 printer , in printing a picture from computer with solid back round black comes out with lite narrow black almost gray & solid wider black lines
jaylex
  • 417 Answers
SOURCE: Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Posted on Jan 14, 2008
SOURCE: prints grey not black
if the printing preference is on "draft", it will print everything on light color or grey. check the printing preference, choose text or image instead of draft.
Posted on Mar 05, 2008
JULIANFIX
  • 975 Answers
SOURCE: hp f380 with Visa OS not printing black
when ready to print go first to where it says PREFERENCES click there , and then slect BLACK CARTRIDGE ONLY ,just to be sure that is not the cartridge ,fun a print , see what happens. hope this helps
Posted on Apr 26, 2008
  • 41 Answers
SOURCE: Cannon Pixma MP500- I get a solid black line on
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Posted on Jun 23, 2009
SOURCE: HP D7260 can't print color in black & white only - greenish hue
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Posted on Aug 01, 2010
I hit the print button for google docs or my e-mails but nothing happens.
On my Cannon printer the computer software was corrupted. I got the printer's install disk (first) and deleted the printer off my computer. I then rebooted the computer. I then installed the printer as a brand new printer. My problems vanished.
Dec 28, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp 4050 does not print gray
Please try to edit the setting of your printer particularly the printing level of your printer such as the ink it consumes and the color of the ink you are going to used. So if you want to have a good quality result then please select the best quality printing it can give of your printer by editing the printer setting.
Thanks
Aug 18, 2009 | Office Equipment & Supplies
Black Cartridge Not Being Used While Printing
try printing in monochrome mode or gray-scale mode, and specify that it use only the black cartridge.
another problem could be that the head have gotten dry, remove the cartridge, get a soft cotton towel, wet it with a little bit of water, put the head of the cartridge (where the ink comes out from) on the cotton towel, you will see some ink come out of the cartridge, if yes, then put the cartridge back into the printer, and give it a try.
if not try to blow some air into the cartridge as if doing CPR ;) to the cartridge, this will help the ink get out of the cartridge.
if all this fails, get a new cartridge, as sometimes the head could have gotten damaged.
good luck
Mar 25, 2009 | Dell A940 All-In-One InkJet Printer
Printer cant print in black and white
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Mar 03, 2009 | Canon MP610 Photo All-In-One Printer
Printer Pixma MX700 will only print in color not black and white?
Try going into Control Panel and click on printers. Normal 0 when the next window comes up, Click on MAINTENANCE, the Properties page will come up and this is where you can do the NOZZLE check/clean and other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Jan 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Print coming out gray even with brand new HP cartridge
either it could be set in the printer properties to print in gray scale or it could be the lens of the printer that needs replacement as if the lens go weak the prints come out very light.
Dec 15, 2008 | HP LaserJet 4 plus Printer
Hp f380 with Visa OS not printing black
Apr 01, 2008 | HP DeskJet F380 All-In-One Printer
k24674
