Question about Mackie SRM350V2 POWERED SPEAKER
Mackie srm 350v2 speaker packed up
Just stopped working solo singer low volume always have volume at 2o clock just guitar vocal backing tracks checked fuse ok leads all ok no blue light no sound ---help steve
I am looking for a service manual of SRM350 v2 please can any 1 help denzeboy5@gmail.com
Posted on Mar 19, 2015
    Scholar:
    New Friend:
  • 125 Answers
I believe there is an internal fuse in these which, according to a friend who has these, seems to blow occasionally for no apparent reason. He has also had to send two back for replacement and would not buy again, they seem to be inherently unreliable although they sound great.
Posted on Feb 18, 2014
  • 1138 Answers
SOURCE: can't get sound out of the main outs just the solo
Here is the manual if you don't have one:http://www.mackie.com/pdf/archive/cr1604_om.pdf. There are solo buttons for each channel. There is also an auxiliary return solo button. There is also a solo to main button. These buttons are all inter related. Is your main output mute button in or out? Read the manual carefully as there are a myriad of combinations you can use. Have a look at the trouble shooting guide on page 21. If you can't find a solution try contacting Mackie. Let me know if this helps.
Posted on Jan 25, 2010
  • 5603 Answers
SOURCE: How do I replace the fuse on a Mackie SRM 350 v2?
The fuse is inside and is to be replaced ONLY after you repair the cause of it blowing. Additional damage may result if repair is not made first. Power it up with a 150 watt light in series with the power cord as a resetting fuse. When light remains out, unit should be good.
The fuse is mounted on a circuit board behind the power input connector.
Here is a link to a service manual that is probably close to your unit:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down at the web page to a small link that says "Get Manual" Click on that and after download unzip the file... it is free... ignore the winrar thing...
Posted on Apr 02, 2011
  • 5603 Answers
SOURCE: 2nd time i went to
Unless you are electronically adept, this is NOT DIY. Take this to a shop.
Posted on Apr 29, 2011
  • 8 Answers
SOURCE: ONLY GETTING MUFFLED SOUND FROM
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
Posted on May 05, 2011
SOURCE: I have a Mackie cv1604 which suddenly stopped
same problem here.. gimme a holler if you've figured anything out.
mine, channels light up, it's getting sound (input) from mics, but it's no sound coming out. i'm almost definite the problem is with the main mix slider. but then again i could be wrong.
Posted on May 19, 2011
How to setup a vocals
Turn gain CCW. plug microphone in, mute the channel. turn gain CW until peak LED flashes (while singing loud!) and turn gain back a little bit.
Take the channel fader down, unmute the channel. Put masters at 0dB (near maximum) and adjust the loudness with the channel fader to what you like.
EQ: it always depends on your location. Keep it flat. You might like to reduce at about 200-300 Hz. Cut the low end (Hi Pass Filter = on) or if no HiPass reduce "bass" for about 6...10dB.
ok?
Mar 29, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
No mic coming though on vocalist live 4
Sounds like the mic you are using requires "Phantom Power." This means, you will likely have to purchase an external unit for this power (+48V) power to the unit. I use a Behringer Ultra-Voice Pro for mine. Works great!! You can find these on Ebay at a steal!
Jan 13, 2013 | Digi-Tech Digitech Vocalist Live 4...
My bass buzzes when im trying to record. I plug it straight into the back of my 8 track and it buzzes. When I touch the metal conection were the jack goes or touch the jack the buzzing stops. This is also...
The cause is a lack of proper earth grounding in the 8 track so your jack-lead is acting like a radio aerial. The solution is simple - buy a Direct Injection (DI) box to place between the guitar and recorder.
Feb 09, 2011 | Epiphone Thunderbird IV Electric Bass...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
I open the Amazing SlowDowner Lite for Mac OS X and there is no track list, even after I've refreshed the tracklist as per the instructions.
Strange thing... we just got the Grappelli violin thing which uses the same Slowdowner from HL... We already had the full blown Slowdowner and we did not let the Lite version overlay the full version we have... When we open the SlowDowner it shows a bunch of track numbers, NO NAMES, but they do contain the audio expected. Exploring the properties the disk is absolutelyFULL. I am on a PC so I don't know what you have on the Mac to look at the file properties on the disk...
In our case I have to load Slowdowner and the tracks appeared... HOWEVER before we did one thing they did not pop up...
You have to tell it to open a CD rather than FILE in the one window !!!!
Jan 21, 2011 | Hal Leonard Broadway Standards - Pro Vocal...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Dec 30, 2008 | Yamaha Electric Guitar
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
Mackie SRM350V2 POWERED SPEAKER Logo
166 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
