Question about Bosch She3Ar56Uc Ascenta Series 24" Recessed Handle Dishwasher
Bosch dishwasher wont start sanitize and auto lights blinking
5 Suggested Answers
SOURCE: Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
Posted on Dec 31, 2008
SOURCE: we have a Bosch shu33 it started running a longer
I got answer from previous post on your site by 'boeschbrady'.Person had same problem,also said part was under Warranty. we called the store where unit was purchased and my unit is also under Warranty "less than 5 years old' repair man is coming next week.Thank you for a
great site Patee
Posted on Jan 11, 2010
  • 457 Answers
SOURCE: my bosch dishwasher model shu33a keeps
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Posted on Feb 27, 2010
  • 6 Answers
SOURCE: My Bosch dishwasher stays running in the wash
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Posted on Oct 05, 2010
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why do i have a problem with my Bosch diswasher mod:she9er55uc/51 ...sanitize and refil rince are flashing when i start the machine
The rinse light is telling you the resiviore is empty and should be refilled the sanitize means that option is choosen try resetting options
Jun 25, 2014 | Bosch 800 Plus Series SHE9ER55UC 24...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
Not drying and sanitize light is not coming on. Dishes are WET
is it draining ok? Are the cycles really long? if yes it might be a control module problem also found on other models.
Bosch Dishwasher Stuck on 2H
bosch dishwasher troubleshoot manual
I soldered mine. works.
keep us updated.
Nov 05, 2009 | Bosch Evolution 300 SHE33M05UC Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Bosch She3Ar56Uc Ascenta Series 24" Recessed Handle Dishwasher Logo
1,036 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
