HAVE A BRAND NEW CANNON MX172 ALL IN ONE & WHEN PRINTING A PICTURE FROM COMPUTER THAT HAS A SOLID BLACK BACKROUND, BLACK COMES OUT WITH LITE BLACK LINES & SOLID BLACK WIDE LINES, NOT SOLID BLACK
hsanfor
  • 71 Answers
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
Posted on Jun 20, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
  • 41 Answers
SOURCE: Cannon Pixma MP500- I get a solid black line on
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Posted on Jun 23, 2009
  • 44 Answers
SOURCE: stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Posted on Aug 21, 2009
byron21
  • 151 Answers
SOURCE: Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Posted on Sep 23, 2009
I hit the print button for google docs or my e-mails but nothing happens.
On my Cannon printer the computer software was corrupted. I got the printer's install disk (first) and deleted the printer off my computer. I then rebooted the computer. I then installed the printer as a brand new printer. My problems vanished.
Dec 28, 2016 | Cannon Office Equipment & Supplies
Cannon A70 black screen, can snap picture but come out with black pic too
try reseting the cam to the factory setting and if still nogo have to upload the firmware.
Jun 24, 2008 | Canon PowerShot A70 Digital Camera
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
I have a iriscanner anywhere 2. When I scann a white piece of paper on my scanner the backround does not come out white. Then when I print it the printer prints the backround and uses a lot of ink. How do...
Almost every scanner can be set for color, greyscale, and black and white. For text only scanning, use black and white and ink will only be used for the text.
Sep 06, 2011 | Cameras
Describe how do I move the Cannon Picture suite on my old computer onto a flash drive so I don't loose my pictures?
Cannon Picture suite is only the sofware installed on your old PC. You just browse the folders in your Canon Picture suite to locate folder that your Picture data are stored. Then you just select the Pictures you needed to save it to your flash drive using the "copy & paste" method.
Hope it helps.
Jun 04, 2011 | Lexmark OCR/OMR For Document Distributor...
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
New HP CM2320fxi printing solid black pages
The Black Toner it came with was faulty, apparently a known issue with HP - though HP Support in the UK has asked more about the computer software though the printing was with photocopying, internal reports etc.
Nov 17, 2008 | Office Equipment & Supplies
Canon NP 6030 photocopier is printing all black. Cannot rectify by altering shading setting. Appreciate any help to fix ASAP. warrengevans@tadaust.org.au
Hi
If it is solid black with no hint of an image in the backround, its an exposure lamp or exposure lamp fuse. Both are not user replaceable. To check, open the copyboard(lid over the glass) and push the print button. If you dont see the lamp come on under the glass it is most likely one of the 2 things mentionerd above.
Oct 30, 2008 | Canon Office Equipment & Supplies
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
jasbo
jasbo
