Question about Dualit 20247 2-Slice Toaster
Testing a dulit element with a multimeter - Dualit 20247 2-Slice Toaster
How can I fix my kenmore range model#c96863589-1 the oven only will not heat up what could be wrong. is it elements
Possible element faulty or switch unless you have a multimeter and a good working knowledge of electricity be very careful. Remove the two connections on the element and set the multimeter to diode testing or resistance and test across the element if you get a zero reading the element has blown, if you get a positive reading look at the switch.
Apr 25, 2014 | Kenmore 96422 / 96424 / 96429 Electric...
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
Ariston Troubleshooting
follow this test and use the multimeter and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating element(s) and replace if faulty
.Test and replace a heating element:
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
Oct 27, 2013 | Water Heaters
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
IHAVE A HOVER SIX TC650 WHICH WILL NOT HEAT UP ALTHOUGH THE DRUM IS WORKING FINE AND SPINNING.HAVE CHECKED THE FILTERS AND THEY ARE FINE.WHAT CAN BE WRONG
Hi.
Test and eventually replace the Dryer thermal fuse
The fuse is located on the blower wheel cover.
The fuse can be tested using a multimeter.
If the fuse has continuity , then is good.
Test the heating element and the thermostat Thermal cut-off .
Both are tested using a multimeter to read impedance. Set multimeter at Rx1, on Ohms.
To test the element disconnect element and point tester probes at element contact.
If there is no continuity, and the circuit is open, then the element is faulty.
The thermostat can be tested jumping its wires to bypass it, but there are many safety concerns doing this kind of test.
Better disconnecting the thermostat and reading Ohms, as for the element.
At room temp the thermostat must have low impedance, if it goes to infinity, and circuit is open at room temperature, then the thermostat is bad.
If both test good, and you have no heating at all, then it may be a bad electronic control, or a wiring problem.
All test and repair must be done by a technician.
If you need to contact a technician you can call the number listed on the owners manual.
Nov 14, 2009 | Hoover Dryers
No heat but have strong air..
Nov 13, 2009 | Kenmore Dryers
Heat element does not kick on. Checked both limit switches OK. Have 120v to both sides of the element however it does not heat up. Help!!
Hi.
If you have volts at the element , and the element does not heat up, then the element has blown.
The element is tested using a multimeter on Ohm on the element contacts.
To do this you need to disconnect the element and point multimeter probes at element contacts. Multimeter must be set on a low impedance scale, eg Rx1. If the multimeter returns open, or go to infinity (same thing), then the element has blown.
In a similar way you can test the thermostats. This can also be tested bypassing them.
Do all test with power not connected. Repairs must be done by trained personal.
You can find parts and diagrams here.
Regards.
Enter mode
Nov 09, 2009 | Kenmore 63952 Electric Dryer
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Jun 21, 2009 | Miele G848I Dishwasher
Dualit 20247 2-Slice Toaster Logo
60 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
