Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I have a hp deskjet 3052A printer and I'm trying to enable wireless printing. It said to enter a pin in my routers configuration. I'm on my routers IP address and see configuration but don'
SOURCE: port forwarding trouble
enter admin for username and password
Posted on Aug 05, 2008
ayamaya
  • 143 Answers
SOURCE: xbox live
you can set a static ip address to your xbox if it's not detecting it automatically.
in order for you to know what ip address to set, go to the command prompt (for windows xp: click on start, then run, type cmd). when you're on the command prompt, type ipconfig/all and hit enter. tahe note of the default gateway, subnet mask and dns 1 and 2. for example, the default gateway is 192.168.1.1, you can set your xbox using the ip address 192.168.1.2 and up (note: you just need to make sure that you are going to use an ip address that is not being used by any other devices that are also connected to the router).
hope this'll help you
ciao!
Posted on Oct 22, 2008
sk8er1707
  • 58 Answers
SOURCE: I have a Westell router through Verizon. My
sometimes the default gateway is not always 192.168.1.1 sometimes it is actualy your ip adress for example 192.168.0.1 but that won't always work so go to command prompt and type 'ipconfig" and press enter first try your ip and then try the default gateway... for any more help please pm me for any more help...
Posted on Jun 06, 2009
SOURCE: I recieved the specified router and I cannot find
are you talking about the security key? if thats what your lloking for it should be located on a sticker on your router. or by default there shouldn't be any password on it. i suggest call your manufucturer to help you reset your router
Posted on Apr 02, 2010
Matrix12
  • 370 Answers
SOURCE: hi i am trying to
Welcome to FixYa! I believe that when you're trying to connect wirelessly it's not asking for the network key or other users are able to connect to your network. Please follow the steps below for you to be able to make your connection secure.
1 Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2 Use "admin" as the username in the pop-up box and leave the password blank or try to use " admin" as the password as well.
3 Connect to the Internet and click on "Internet Setup."
4 Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5 Set a service set identifier (SSID) to identify the router and change the password.
6 Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router
Hope this will help...Thank you for using Fixya...
Posted on Mar 03, 2011
Print with out wireless
That's right. You don't HAVE to use wireless to use a wireless printer.
Feb 12, 2015 | HP Deskjet 3052A Wireless e-All-in-One...
PRINTED IMAGES SLIGHTLY OUT OF FOCUS SINCE CHANGING PRINT CARTRIDGES
Most printers have a "UTILITY" program that will let you align the print heads. I would start there to correct the problem.
Sep 22, 2014 | HP Deskjet 3052A Wireless e-All-in-One...
What does WPS error mean while trying to connect towireless
Check your wireless router and just disable wps option and try again
Dec 14, 2013 | HP Deskjet 3052A Wireless e-All-in-One...
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
My wireless printer hp deskjet 3050 is not printing the wireless blue light keeps blinking and does not go solid like it used to what do i do?
if the wireless blue light is blinking, it means it's not connected to the router or it's not communicating with it.If wireless blue light is solid ,it means it's connected to the network.
you will need to reconnect the printer to the network by using a USB cable.it will configure the wireless connection.
  1. to start the installation ,click on the start button on the computer
  2. click on programs or all programs depending on the operating system on the computer
  3. look for the HP folder and then left-click on it
  4. inside the HP folder,left-click on DESKJET 3050a or DESKJET 3050 series
  5. inside the DESKJET 3050 folder, left-click on product setup and software
  6. left-click on connect a new printer
  7. it will open up a page with options on how to connect the printer
  8. select wireless and then hit next
  9. if you are prompted to connect the usb ,please connect it
  10. if it asks you whether printer is connected to the network,select no
  11. click on next
  12. if usb is already plugged in,tick the box that says it's already plugged in
  13. hit next
  14. wait for the prompt to unplug the cable
  15. try printing wirelessly
let me know if these steps do not solve your problem.
Jul 15, 2011 | HP LaserJet 3050 All-In-One Printer
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Dec 03, 2009 | 2wire Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
229 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
