Charmglow electric fireplace model 23E02 wont flicker
It has stopped flickering
5 Suggested Answers
jamesmarcum2
  • 79 Answers
SOURCE: fire wont flicker on my electric fireplace
most of those electric fireplaces have a band of paper with holes in it that rotates around a light bulb this gives the illusion that the fire is flickering the motors that rotate that band of paper go out all the time its just a little electric motor you might be able to get one from the manufacture
Posted on Dec 07, 2012
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 3 Answers
SOURCE: Charmglow electric fireplace flame does not
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Posted on Dec 28, 2009
  • 193 Answers
SOURCE: Charmglow fireplace, everything on, no heat
its either a sensor or the element most times sensor or limit.
Posted on Jan 25, 2010
Fire wont flicker on my electric fireplace
Dec 07, 2012 | Heating & Cooling
I need to get a manual for a Charmglow electric fireplace Model # CGN250TED-C 25,000 BTU Pure Comfort solutions and I cant find a website, i need to know where to change it from natural gas to propane. ...
I am almost totally confused. You started out saying you have a Charmglow Electric Fireplace. Then you said you want to change it from natural gas to propane.
Could you please be a little more specific in what you have? So I can help you. As Charmglow only makes Electric Fireplaces. No gas ones.
Thanks, I look forward to hearing from you.
Aug 10, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a Delonghi type Venice fireplace serial no 52013. Normally it has a nice flicker which goes up the back of the fire place and looks like a normal fire. Today the gentle flicker has turned to a very...
Did you fix it as I have a Delonghi Venice electric fire which has just stopped working for no reason? There is electricity going to the circuit board but nothibg is working. Could this be a faulty remote control?
Aug 28, 2010 | Heating & Cooling
Charmglow electric fireplace bad remote control
Here is the home site for Charmglow - you could try to call them and see what they say. I would hope they want to keep their customers:
Charmglow Products 3701 Charlotte St, Pittsburgh, PA 15201-3201 (412) 683-6434 .aBtnGetDir { display:inline-block; width:107px; height:22px; text-decoration:none; vertical-align:bottom; cursor:pointer; } .aBtnGetDirLeft { float:left; height:22px; width:92px; overflow:hidden; font-size:0.85em; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -99px -401px; color:white; font-weight:bold; text-align:right; vertical-align:middle; line-height:22px; } .aBtnGetDirRight { float:left; height:22px; width:15px; overflow:hidden; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -301px -401px; }
Dec 12, 2009 | Kitchen Appliances - Others
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flickering lights have stopped working
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
Jun 18, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame doesn't flicker
The "flicker" function in my unit operates with a system of rotating, reflective fins. The tiny, AC synchronous motor driving the fins failed and I got one one-line for cheap. A fairly simple R&R.
Only downside is the motor does not always start in the proper direction, but a start/stop or two resolves the issue.
Apr 08, 2017 | Kitchen Appliances - Others
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
