Question about Dirt Devil CE6100 Featherlite Upright Vacuum
How do i get it to **** up the solution after i shampoo
How do i get it to suck up the solution after i shampoo
  • Dirt Devil Master
  • 18,402 Answers
Go here > http://dirtdevil.com/file/106/ for the manual
Posted on Jan 02, 2013
My shampooed won't pick up ythe water
does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
Jul 01, 2017 | Vacuums
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
My shampooer only sprays a single stream of shampoo and water whenever I use it on the carpet... That and I can't get it to lay a nice even layer of shampoo to soak in and then pick it up...it always does...
You are probably missing the foam screen on the tank outlet. There should be a plastic disk with a fine screen in it on the tank outlet. If the screen is missing, foam will not be produced; and just soap water will be sprayed out. Sometimes the screen assembly can be found in the end of the shampooer hose.
Nov 01, 2010 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Vac not sucking up water
its supposed to, it means you need to dump out the tank. Its a safety feature that keeps the water out of the motor. if its lifting up due to foaming, than try using the original brand shampoo
Jul 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
PROBLEM
Well with a Kirby shampoo system there is no actual suction to clean up the water, they use a foam to clean if you are using the genuine Kirby shampoo, what the brush does is scrub and collect excess foam, I've used them before and really I'm quite pleased with the Kirby shampoo set it doesn't take as long as my parents Bissell did to dry
Jul 17, 2008 | Kirby Heritage II Vacuum
Minuteman ambassador jr. shampoo extractor
roro, There are two possibilites: One is that each hose does something different (suck and exhaust) or both suck. Find the one that sucks. That should be the one that you hook tools to now. If the attachment has an electrical connection, it will be needed to do scrubbing. If the shampoo unit is from a different brand, you'll have to make up something to do that. If you do, be certain that the connection is fully taped up so no liquid can get to it!!
Dec 06, 2007 | Vacuums
Suction
Opening that door and attaching the hose will let the suction go thru that hose. So if when you removed the hose, if that door isn't closed tight will cause you to have a suction problem It has to seal and have no leaks. The other thing when be a problem with the recovery tank not sealing when you put it back on. Other then that, any air leak will cause a suction problem.
Apr 19, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Dirt Devil CE6100 Featherlite Upright Vacuum Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
