Question about Microwave Ovens
How many screws hold the kenmore microwave # 89655 up, I only see 2 toggle bolts
I only see 2 toggle bolis going though the shelf that it is suspended from. I would think there were at least 4. It weighs 58 pounds.
techman
  • 3130 Answers
SOURCE: CHANGING LIGHTBULB ON MICROWAVE
they should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
Posted on May 21, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: remove kenmore microwave model 7218815180, 1988 model
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
For some models, manuals are available free if a button shows up to the right of the parts listing.
Otherwise, you will need to order an installation / owner's manual from the parts list.
If it doesn't show up, you can contact support via phone numbers available through that page's links.
Posted on Sep 28, 2008
  • 13 Answers
SOURCE: One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Posted on Dec 31, 2008
micromaster
  • 3614 Answers
SOURCE: I can't find bolts or
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Posted on Aug 04, 2009
  • 142 Answers
SOURCE: No studs for microwave installation
If you can secure the mounting plate with four toggle bolts plus the two screw in front you will have no worry.
Posted on Sep 27, 2011
Removing unit
To remove, you will need to remove four bolts on the top of the unit.
Unplug it first, then remove the two bolts nearest the wall first. It would help to place something under the front of the unit about two inches shorter, to catch the unit as you remove the front bolts. The bolts are long, so be prepared for a lot of turns. A ratchet helps. The unit will lower in the front as you remove the last bolt. There is a bracket screwed to the wall behind the unit, with a lip at the bottom that holds the back of the unit. After the front has lowered, lift the back up about an inch, and pull the whole unit away from the wall. Remember to pull the power cord out of the cabinet before moving the unit away. Hope this helps.
Jun 14, 2014 | Kenmore 62702 Microwave Oven
Shooting sparks out left side near bracket for shelf
if there are any sparks inside the cabinet it is time to throw the microwave out or send it out for a powder paint $$$$$$
Nov 27, 2013 | Kenmore Microwave Ovens
How to remove the old Tappen microwave oven model 56-2891 under the cabinet?
open the cabinet door above the microwave there should be four screws going thru bottom of the cabinet shelf holding it on to cabinet have a helper hold the microwave as you unscrew it
Dec 12, 2010 | Tappan Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
Hope this helps.
Aug 04, 2009 | Microwave Ovens
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Spacemaker XL1400
I found a solution for my microwave. Went to Ace and picked up some lag bolts, yellow in color (believe they said it was yellow zinc). Most common seems to be 1/4"-20, but these lag bolts had the smaller thread of 1/4"-28.
I had to go a little shorter in length because the threads don't run the entire length of the bolt. The only downside is that the top of the bolt sticks out inside the cabinet (but only about 3/16"). Well worth it so I didn't have to buy an installation kit that was in the $40-$50 range.
Dec 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
There has to be something in the wall supporting the drywall. You need to find the supporting structure using exploritory holes if necessary and solidly fasten to it using lag bolts.
Jan 11, 2008 | Microwave Ovens
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave installation
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
