Question about Quasar VV-2002 20 in. TV/VCR Combo
Blinking light front of TV
I have a Quasar Model VV2006 that has some type of blinking light going in the front of the TV. Very small light located on the bottom left some type of timer indicator. Light came on when I unplugged the set. When plugged back in light started blinking. How to i reset.
You need to set the clock. The timer is confused if it dose not know the time.
Posted on Jul 15, 2009
  • Quasar Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
I have a Sony tv model # KDL-50EX645 that will no power up. There are two small green led's that are flashing on the front of the tv. Any idea on how to repair it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 06, 2016 | Sony Televison & Video
I have a Panasonic tv model # PC_TC42S2 tv will not come on red light on front on front tv set blinks 10 times. what wrong with this set?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 30, 2014 | Televison & Video
Power light flashes 7 times every 5 seconds but TV won't come on 2011 Panasonic plasma 50in flat screen TV model #tc-p50s30 it has a small crack on the right side of the screen were it was jarred
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 25, 2014 | Televison & Video
Tv won't come on, the small green light to indicate power on is instead flashing red on and off for a few seconds then stops. I disconnected all power for a few hours, then reconnected power and it worked....
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 10, 2017 | Panasonic TCP50C2 50 in. TV
Sony 53" rear projection tv picture comes on scrambled and small with the stand by light blinking then the lamps go out. Whenever the channel is changed stand by light blinks again lamps come on for a few...
There are 2 types of Sony rear projection TVs, one that has 3 picture tubes inside and other has one lamp to produce light.
Model number is important to identify what TV do you have so let me know exact model number written at back of TV to find problem reason and suggest its solution.
Thanks.
Nov 30, 2009 | Sony DAV-C770 System
Was running a wash cycle lastnight and it stopped running and the clean (green) light is blinking and won't turn off. When I push the Start button, there is a red blinking light. Help. It is a Kenmore...
Is your washer a front load? Does it have a small window where you read the stages or minutes left?
If so is there a code flashing in thet window?
Also what year is your model?
Oct 21, 2009 | Kenmore Dishwashers
My universal remote will not work on my VV2006. I
Get codes from
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
try new code. Try different remote. then go to tv menu, find "autoprogram" feature and select it. It will scan all available channels
Aug 27, 2009 | Quasar VV2007 20 in. Combo
Toshiba 57h81 red light blinking
http://electro-medical.blogspot.com/
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Sony KV36FS100 - Has sound but no picture and stand by light blinks when TV is off
Aug 24, 2017 | Sony KV-36FS100 36" TV
Quasar VV-2002 20 in. TV/VCR Combo Logo
463 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
