Question about Conair HC500 Hair Trimmer
Cannot find the part for Clipper Blade HC500-BLD1 online
2 Suggested Answers
d_duffer
SOURCE: Need the plastic part on the blade, that are
I have a Conair GMT180 Beard trimmer, blades have become dull, and it is pulling hair instead of cutting them... Where can I get blade(s) for it and how mmuch including Shipping..... Please respond by sending email with purchase link to d.duffer@insightbb.com
Posted on Nov 20, 2012
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Clipper has power but the blade doesn't move
Make sure the blade is connected to the clipper correctly, if you can pull the blade off without pressing the black release latch then you need to push the blade on further.
Apr 05, 2014 | Andis Agrc Power Barber Grooming Dog...
It's not cutting anymore, my husband greased it and cleaned it but it's not cutting, barely grazes the top. how do I know if the blades are sharp anymore. we have only used it 2-3 times on our cocker...
If you have another clipper, you can test the blades out on them to see if your blades are sharp. As for the blades not cutting on your clipper it could be a couple things. Your blade drive could be worn and not allowing the cutter blade to travel far enough each way to make a clean cut. Another thing to check is that your blade latch is not broken. This is the black hook by the blade drive on the clipper. If the blade latch is broke, the blade won't stay tight up on the clipper. Thus the blade will act like it is dull.
Mar 12, 2011 | Oster Golden A5 2-Speed Universal Motor...
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
How do you put on a blade when you took it off?
There is a picture of an oster clipper in the picture so I assume you are talking about an A5 style blade/clipper. Hold the clipper with the hinge facing you, if the hinge is open, then turn the blade so the blade number is facing up and slide it onto the open hinge, start the clipper and push the blade down to shut it. If the hinge is not open, prize it open with a flat head screwdriver. www.sheaeaseltd.com
Jul 12, 2010 | Oster Golden A5 2-Speed Universal Motor...
How do I put size 4 blade on clipper
The A5 clipper should have a locking hinge the hinge should be open and slide the clipper blade onto the hinge, now push on the clipper blade bachward and it will snap on. if you don't hear a snap sound the hinge on the clipper maybe worn out and don't have no spring tension.
Mar 27, 2010 | Oster Golden A5 1-Speed Universal Motor...
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
Health & Beauty Logo
271 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
