Question about Canon PowerShot S2 IS Digital Camera
I can not get my Power Shot S2 IS battery door open
I don't know if lock is broke or what but I can not get it to release.
With the camera upside down. slide the latch to the right, with the same motion slide the door to the front of the camera. I had to gently pry the door to move a little. you might find that there are no batteries currantly in it. thats the way i did mine. good luck your on your own.
Posted on Jan 07, 2013
  • 164 Answers
SOURCE: My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Posted on Jul 22, 2009
t00nz
  • 4738 Answers
SOURCE: I have a power shot S2 IS digital camera. I have
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
For your particular model camera, pay attention to the UPDATE intro to the article.
Posted on Oct 12, 2009
SOURCE: CanonPower Shot S2/IS. The Zoom lens is stuck open.
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Feb 07, 2010
  • 141 Answers
SOURCE: My lens is stuck in the open position on my Canon
Unless you know your way around the innards of the camera I wouldn't advise trying it yourself. What you have is a very common problem with all retractable lens cameras and to fix them requirers a complete strip of the whole camera. It could be a foreign body like a grain of sand jammed between the lens elements or the lens body and the camera body. I have seen one fixed with a very lucky blast of compressed air but it's a thousand to one chance. It could also be a knock to the lens whilst being extended and it's been knocked out of alignment. One other thing could involve the sensor or motor which drives the lens in and out. So there's a 99% chance of it needing a complete strip down and it's not something I'd recommend an owner tackles. For one thing it's a fiddly job and another is a chance of a few thousand volts shooting up your arm, and that hurts, believe me.
Posted on Apr 21, 2010
  • 102366 Answers
SOURCE: I have a Canon Power
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Aug 16, 2011
Need help battery dead and doors locked
This probably far too late but you can open the driver's door manually with a key regardless of battery condition.
May 05, 2013 | 2002 Land Rover Freelander
Cannot open front passenger door from inside or outside.
From Freeport Have to take panel off and rehook the locking arm it's a buger to do
Jan 10, 2013 | 1991 Chevrolet S-10 Blazer
1996 BMW 740 il the front passanger side door is closed, lock broke and don't know how to get panel off,
If you can't get the door open then you can't get the panel off its as simple as that, there are screws under the door card that need to be removed to gain access to the inner door workings, without getting the door open you would have to remove the wing to gain access to the hinge bolts & remove the whole door from the vehicle, then you may still have problems with the door having its mechanism locked around the door frames pin or loop
Sep 13, 2012 | BMW Cars & Trucks
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Doors wont lock. Windows won't work. Car thinks the door is locked because when I open the hood alarm goes off. Security light is flashing when doors are closed. Locks don't engage when driving...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door. Could be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released. It could also be the body control module.
Aug 28, 2011 | 2003 Volkswagen Jetta TDI
I have a 1995 Grand Marquis that has lost all power to the keyless entry, all door locks, and trunk release button. Looked at fuses figuring that was gonna be problem but fuses were fine. Don't know...
check fuse 8 & 14 in dash apnel.
also 40 amp fuse in engine comartment fuse box
if all good, it is the driver door module that controls all these functions.
13C797 base part number Driver Door Module
remove dr door trim panel for access.
search ebay with base number, may get lucky
Jul 13, 2011 | Mercury Marquis Cars & Trucks
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Canon PowerShot S2 IS Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
