Question about Brother Sewing Machines
My brother started making a loud noise when sewing pant fabrics
It is making a clunking noise when the needle goes down into pant fabrics that I am hemming. I changed the needle to a jean needle, but it did not change the noise.
  • Brother Master
  • 1,564 Answers
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Posted on Jan 03, 2013
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 106 Answers
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Posted on Mar 29, 2008
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
  • 11 Answers
SOURCE: How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Posted on Apr 08, 2010
  • 17 Answers
SOURCE: The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Posted on Aug 15, 2010
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
With each stitch the machine makes a loud clacking noise and needle broke
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time--needs to be checked at a repair
shop
Sep 10, 2012 | Brother Sewing Machines
Lould noise when sewing. already, cleaned inside, oiled, changed thread, needle and begins to sew correctly but while sewing becomes loud again. bobbin casing does not appear to be damaged. machine is...
Have you taken your throat plate off and cleaned that out? You have to take a stubby short screwdriver and remove the throat plate. Sometimes, lint and cloth build up in there and it looks like felt almost. I was surprised when mine had it, I always followed the standard way of cleaning and lubricating until my friend told me about this. I was shocked, to say the least, that she was right. And my machine quieted right down. Hope this solves your problem
Dec 30, 2010 | Brother CE4000 Computerized Sewing Machine
The needle comes unthreaded when machine is started brother 2600 I
Pull both bottom and top thread to the back of the machine for about 10 cm or 4 inches out before you start stitching. Hold them loosly. Put fabric under the foot (the whole foot, don't start at the raw edge), make sure foot is down (to ensure tension). Start with the needle in the top position.
Your needle is likely to become unthreaded when the needle goes down and back up. But not if you hold the thread (and enough of it). Happy sewing.
Dec 24, 2010 | Brother XL-2600
Apr 08, 2010 | Brother CS6000i Computerized Sewing...
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
I have a Brother ex-660 and it is making a thumping noise, it seems to make the noise every time the needle goes down into the fabric. I noticed the plate under the fabric is chipped (could be from the...
Change the needle and then using the side wheel wind through the stitch process manually. If the needle is still hitting something down under the needle plate, then your timing is out, take it to a mechanic.
Oct 07, 2009 | Brother Sewing Machines
Sewing Machines Logo
463 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
