Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
G 646 sc pump still runs when programme is off
Also red light on
    New Friend:
I had the same problem, the drain pump kept working even on the off program. After a little investigation i found out that there is a leak sensor that triggers the drain pump continually until it does not "sense" water anymore.
Firstl i tried to open the rear panel with no success.
Next i tilted the dishwasher to the left and let all the water drain out, plugged the dishwasher back to electricity and it worked!!!
I hope it will help you.
Posted on Jan 09, 2013
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Miele G 646 SC, Leaking.? My Miele G646SC is leaking, the red inlet/drain light is on and I suspect it may be one of the pump seals has perished. The machine is 11 yrs old and has never had a problem of...
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Nov 28, 2017 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher not completing the programme and water not draining away.
check for a drain clog. If not clogged, your drain pump in the washer may need servicing.
Mar 29, 2012 | Dishwashers
I have a fischer and paykel top loading washing machine for the last few years that that given use excellent service. In the last month when a programme is run the machince gets stuck at the rinse cycle...
Hi dude - is this a replica of the lights - where I put 0 theres no light, 1 is a light ok you follow? on the top is 8 lights from left - right the first 5 is always green, next 2 is orange & last is red! so I will try and see if we are on the same track...
Here goes - 0010 0101 is this what you have? - if yes then the pump is either overheating of severely blocked - more likely to be overheated.
This is how the washer works. it fills, washes then rinses - now pump starts up as machne joggles and agitates to set up for a spin, then final rinse - as it goes to end it does the same as in rinse.
Therefore I tend to think we would be looking at the same lights on your machine - to my illustration -
Keep the chin up - if you need to replace the pump then look up other F&P request or look up my solutions to help you.
KK
Jun 24, 2011 | Fisher and Paykel Washing Machines
Panasonic plasma th42ph10uk power red light blink twice
Manual says problem with SC, SS, or C boards. SC is large board at left when facing rear, SS is large board at right, and C is small long board at very top. You could check fuses on SC and SS. Also, SC and SS should make a buzzing noise(not too loud) if operating. If a fuse is blown, suspect that board is bad not just bad fuse. Search parts at encompassparts.
May 08, 2010 | Televison & Video
Honeywell HCM-646 -Motor not running
There is normally a capacitor to prevent surges across the motor it might the short circuit.# and preventing the motor from starting.
Jan 13, 2018 | Honeywell HCM-646 4 Gallon Humidifier
I have the non-california version and I can't figure out how the fuel lines run from the tank to the carbs.
A service manual is a valuable tool with an aging bike. I suggest the dealer/mfr. or Clymer books. In the meantime, go to the library reference section...646 stacks should have what you need.
Sep 26, 2009 | 1986 Honda CB 700 SC Nighthawk
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
166 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
