Question about Garden
MURRAY HYDROSTATIC AUTOMATIC DRIVE 42"CUT 14.5HP
OLDER MODLES
  • 3 Answers
SOURCE: MURRAY AUTOMATIC DRIVE, 42
Your problem could be caused because your valves are not set properly (they vibrate loose sometimes. Remove your spark plug and try to crank theengine...If it turns freely with the pulug out, reset your valves..be sure to obtain the proper spacing (gap). Hope this helps
Posted on May 06, 2009
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
RonPark
  • 855 Answers
SOURCE: i need a manual for kohler 21 hp 42
You should be able to find what you need at craftsman.com
Posted on Oct 02, 2009
vincob
  • 718 Answers
SOURCE: MURRAY LAWN MOWER WILL NOT GO PULLY IS SPINNING
sounds like you sheared a woodruff key check the key on the pulley. Or maybe your belt is no good or came off the tension pulley anyway that might get you in the right direction.
Posted on Apr 08, 2010
  • 13 Answers
SOURCE: need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Posted on Jan 05, 2011
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I have a Murray 17.5 HP Twin 46" automatic drive riding mower that only moves very slowly. What are possible causes?
If the transmission is hydrostatic and has some hours on it, the transaxle may be going bad. If this has been getting worse as you use it. If the problem happened suddenly, could be a belt loose or stretched.
Jun 26, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
What is a hydrostatic transmisson?
Hydrostatic transmissions are automatic "Hydraulic drive" transmissions. The largest producers of hydrostatic transmissions are Hydro-Gear, Tuff Torque and General Transmissions.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
12.5 hp Briggs and Staton Murray 42 in cut will not move and smoked when put in gear
check the tension of the drive belt sounds like the belt is slipping also check it for oil if you have a oil leak and the oil got on the belt that will make it slip as well
Jul 06, 2012 | Murray Garden
Need diagram to replace murray 42 inch cut belt
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Mower doesn't cut going downhill
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Dec 19, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Adjust the drive belts,
if you have the belt installed correctly, the idler pully is the only adjustment and thats automatic. i trust you have installed the correct belt.
Apr 29, 2010 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
