Question about Refrigerators
The water dispenser on my LG GB7143A2PW1 fridge freezer is not working. The pump runs, however, it does not seem to be making the same noise when operating. It sounds more quiet. Can you help
The dispenser was working earlier in the day, There is water in the container and the door is closed when demanding water. I have checked for blockage there is none obvious.
SOURCE: water dispenser in fridge door
I have same problem with GE monogram 42. ice maker works, water dispenser not. It does click but no water. Help.
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
SOURCE: Water not getting to dispenser, but does get to ice maker.
Hi All,
The fix to the "GE/Hotpoint Secret" frozen water dispenser problem is the Dispenser Water Tube Heater Kit, P/N WR49X10173 that can be purchased at Sears. Just a few bucks. My Hotpoint (model HSM25GFRA5A) had the same issue and GE would not tell me anything but required a technician to come out. The technician had no clue but after making some calls found the heater at Sears and ordered it delivered to me. He had to setup a return appointment but I canceled it after getting the parts and fixing it myself. The instructions are in the kit. Since most all GE/Hotpoint refrigerators (same model group of course) use the same parts/assemblies this will work for lots of folks. See pic below. If the area behind the cover looks like this it may be the part. Feel free to email me for help on this (rkjobe@military.com). Piece of cake.
Posted on Jun 24, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Water dispenser on refrigerator not working but ice maker is making ice
Most likely a frozen line... If you can hear a faint pump noise near filter when you try to dispense wate, that tells you the pump is woking. rIt could be a frozen reservoir(located on fridge side behind vegetable bins) or the line that runs thru freezer door to the dispenser. Use a hair dryer to thaw out reservoir or try to turn off the unit for a few hours. (That did it for me). If it's the line in freezer door, shut off unit, open freeezer door for a few hours and seal off freezer with a towel or cardboard to keep all frozen. If not this, may be a clogged water line from filter or a bad valve.
Dec 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
