Question about KitchenAid KT2651X Epicurean Stand Mixer
Beater assembly stopped rotating, motor makes "whining" sound
Mixer is 10 years old, factory refurbished. Worked like a charm for the past few years...just quit last week. Don't want to send to Kitchenaid for repair...can I take this apart myself and find the problem?
    Novelist:
  • KitchenAid Expert
  • 185 Answers
In a word Yes! There are several videos on youtube that go through a full tear down replace gears and re-assembly process. You will also need a prats list for your model (you will need your full model number as the Epi series have had four or five modifications and you must have the right parts)
http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202
You can figure some type of modification based on the number of parts list available to you when you go to the site above. the top list is for user manuals the bottom list is for parts lists.
You can repair this for about $60.00 in parts plus some patience and a couple rolls of paper towels, hope this helped
Posted on Jun 02, 2013
SOURCE: Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Posted on Dec 07, 2008
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
SOURCE: Kitchenaid 350 stand mixer power problems
I'd check the brushes. The big black screws on the side of the motor casing, easily removed, but becareful when you put them back. Here were some instructions from another site that helped me get them back in right:
The brushes in my model KP50PSBU must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Posted on Nov 14, 2008
ricardok45
  • 135 Answers
SOURCE: Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
hslincoln
  • 235 Answers
SOURCE: KitchenAid Mixer is not rotating.
Hi MANILYNTHEOB. I’m sorry to hear about your mixer not working. Unfortunately from the symptoms you describe, your mixer has experienced a transmission failure. You don’t mention how old your KA mixer is or how hard it’s been used, but for your particular model, KA has a plastic gear designed to fail, instead of the whole mixer ‘going up in smoke’. And what it sounds like is that this fail-safe gear finally ‘failed’ (stripped) so that the power from your electric motor is not getting to your planetary (“elliptical rotating part”) and the agitator shaft. What can you do?
The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and then enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 58, Worm Gear Bracket & Gear, including Illus. No. 12, Worm Gear (23 teeth). I suspect this is the weak link in your mixers transmission and causing the problems. After clearing all the grease away, you’lll probably find that is has been stripped.
You can order a replacement gear and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as this should be filled with debris from the stripped gear.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jul 09, 2010
Repair Hand Mixer
the head gears are not engaging properly
could be the selector knob or stripped gears
get a quote from an appliance repair shop but if the mixer has a few years on ti then it will probably turn out cheaper to get a new one
Feb 25, 2016 | Kenwood Food Mixers
No rotating movement from the mixer, only fast clicking sound after beater was lodged.
This is an excellent mixer and worthy of a professional or DIY repair.. You stripped a gear inside the mixer that is there just for that reason. Now the machine requires a tear down and replacement part. if you can post the model number we can advise on how to do it. If it is the new pro series model they cost between 4 and 5 hundred new to buy, the repair is going to cost between 80 and 100 dollars by a professional or about 30 dollars by you.
Dec 31, 2012 | KitchenAid K45SS Classic Stand Mixer
My sunbeam mixmaster is about 40 years old and suddenly stopped working
The running capacitor finally died. I used to be their factory service tech. You can change it easily by removing the back knob and the handle. The screws are under the silver buttons. The capacitor looks like a 3/4 x 1 1/4' tube with a small nib sticking out each end.
Dec 26, 2012 | Sunbeam 2366 MixMaster Series Hand/Stand...
Teeth on plastic gears for mixer are worn down
Even if you could obtain the parts, a 10 year old mixer is well past its prime.
Jan 17, 2018 | GE 106772 HandStand Mixer
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
KitchenAid KSM50P mixer sporadically stops working
Hi, This sounds like you have an issue with the planetary gear system. The mixer has a plastic worm gear inside the planetary that is prone to wear and failure. I would bet that it needs replaceing.
Mar 13, 2010 | KitchenAid Food Mixers
The mixer will not start. Power gets to the unit and the blade does turn manually.
Hi - I assume you mean to say that the motor turns on, runs in all speeds but no power is being transferred to the planetary head and beaters?
If this was preceeded by some intermittent run conditions like occasionally skipping beaters and some louder than normal or different run noise then it's likely that the nylon Worm Gear has lost teeth and is no longer making contact with the motor gear. It is part of an assembly which is directly coupled to the motor. Disassembly is required to get at this part and some mechanical skill to replace it. If the mixer's a few years old and/or gets a lot of use, the gear grease should be replaced too. For the gears and other parts, including the grease - check out http://www.goodmans.net/get_dept_933.htm They seem to have just about every part needed and fair pricing. Appliance Parts Pros is another source of parts and diagrams. Warning - mixer disassembly is a medium complexity task and could ruin your day...
DZII
Jan 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater too low-will not lock
I would check the bottom of the beater blades to see if they are out of shape.,or is the base of the mixer raised somehow to cause this problem
Jul 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
173 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
