Should my wall heater glow red inside?
Only one of the four wall heaters I have in my home glows red inside. Is this indicative of a problem/fire hazard? I don't know what brand it is. Thanks.
Therinnaiguy
  • 1420 Answers
SOURCE: vent free infared heater
What you are experiencing is common if the plaques are either out of alignment or the burner is dirty. I know you said you cleaned it with low pressure air, but you need at least 120 PS. of air to clean the burner and plaques as per the owners manual.
Posted on Nov 15, 2007
  • 3 Answers
SOURCE: air fuel mixture screw adjustment, forced air kerosene heater
Most ready heaters have a fuel pressure setting on the back of the heater near the fan. There should be two small plastic covers, looking directly at the back, the one on the left can be removed and a pressure gauge installed. The one on the right is slotted for adjustment of pressure. I think the correct pressure for that model is 3.0 lbs.
Posted on Jan 06, 2008
tbugger
  • 232 Answers
SOURCE: I have a Reddy heater Pro 155 that will not start up
Since you did not state anything about the presence of a flame, it sounds as if there is a fuel delivery problem. The Photocell is shutting the heater down because it does not see a flame.
Troubleshooting tips http://www.reddyparts.com/HSI_tips.htm
How to set the air pump pressure http://www.reddyparts.com/pressure.htm
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Directions for changing wick on Dyna Glow RMC95C7
You can find a free downloadable manual here.  There is a signup process, but it's free.
Hope this helps!
Les
Posted on Feb 04, 2009
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Coils aren't glowing red
Most of the new heaters dont glow red. Its a safety thing so it dont catch your sheets or curtains,couch,chair etc on fire. Because of the idiots in this world we cant get a good heater anymore. Thats just the way it is.
Jan 06, 2013 | Comfort Zone CZ792 Electric Utility Heater
Tru glow propane heater plaques not burning properly
They need cleaning along with the injectors /lack of air .
Nov 11, 2012 | Desa International GWP20T GLOWARM Wall...
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
Wall covered with snow
You have a defrost problem , due to the " snow " . Most likely , the problem is a bad defrost heater , pt # WR51X10055 , but I would still suggest going thru the motions to make sure . The heater runs about $45.00 .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
Sep 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The brick does not glow red you see the flame all the time, goes up pass the brick. Is this repairable or dangerous? (Dyna glo gas wall heater -model RMI-70LP)
Both repairable and dangerous. The burner need blown out with a air compressor. This should take care of it. The unit not glowing red will create CO. Which will make you sick or even can kill you.
Jan 06, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I get ice on the back wall of my frizer wall. why is that?
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 11, 2009 | GE GSS20IEP Side by Side Refrigerator
The back wall of my fridge is freezing up... I had a repair man replace two sensors and to no avail then I replaced the mother board and that did not work either... what now?
Unplug the refrigerator . Remove the motherboard cover . Remove the blue plug with large wires from the motherboard . Looking at the plug , you'll see wire1,wire2,space,wire3 . Using a short piece of wire with both ends striped , insert the ends into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom of the rear wall , for a red glow . May take several min . If no red glow , replace the defrost heater AND the defrost thermostat (bimetal ) . If red glow , bad control board .
The defrost heater and bimetal , are behind the rear lower panel inside the freezer section . The heater is at the bottom of the coils , and the bimetal is clipped on at the top of the coils ( blue and pink wire ) .
Sep 06, 2009 | Refrigerators
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
