Question about Pioneer SD-532HD5 53" Rear Projection Television
Pioneer SD-P5185 Rear Projection has intermittent double vision
The colors separate into a sort of double image red and green.  Will be fine for a while then happens then goes back to normal.   If it gets stuck that way for a while I can turn it off and back on and it will return to normal most times. Any ideas?
  • Gallion Feb 17, 2009
    i have the same problem... if i tap the sides it goes back to normal
Sounds as though the output transistor(s) on the color convergence board are going bad or already have. If handy with Electronics; get service manual and check the emitter voltage.
Posted on Jan 31, 2009
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a Pioneer SD-P5185-K rear projector TV that has small lines across the screen and the color changes. Someone said they have a gel pack(?) that might need replacing.
ya i got the same tv and i see double picture on the bottom of th tv if i cover the blue light inside the tv the picture goes back to normal so my problem is with the blue canon inside the tv. is this exspensive to replace???? or fix
Apr 07, 2010 | Pioneer Televison & Video
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
PIONEER SD-P5185-K REAR PROJECTION TV
Bad convergence ic STK4277 I think. A qualified tech should be able to complete inhome for less than 300.00
Craig www.classtorations.com
Jun 06, 2008 | Proscan PS32500 32" TV
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-532HD5 53" Rear Projection Television Logo
205 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
