Question about Brother DS-600 DS Mobile Portable Scanner
Brother dsmobile 600 leaving vertical lines
My scans are coming out with vertical lines on them. it doesn't seem to matter what kind of paper I use. I have cleaned and calibrated it.
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
SOURCE: vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Posted on Sep 03, 2009
  • 68 Answers
SOURCE: Vertical lines in copies and scanning
You need to clean small exposure glass located on the left of the main exposure glass.If this doesn't help,it can be a dust under the glass or on the mirrors that causing lines.
Posted on Oct 06, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 12, 2010
komguy
  • 2306 Answers
SOURCE: Brother 7820N has black vertical line when using ADF
It's the same scanner ccd, after you make sure the narrow scanner window is clean, you need to power down the machine and power up again so it will calibrate to a clean window, if it has a scratch like from a staple, you will need a new glass.
Posted on Jan 18, 2010
Testimonial: "Yes, it was a scratch on the ADF window. Couldn't see it until I breathed some moist air onto the window, then it showed up! thanks for your help "
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Vertical line on paper from top to bottom
In my experience if you refill the toner cartridge with the toners available in the market,though they are labelled"for Brother 2140" you get vertical dark patches on the paper. Once in a while you get good quality print too. Replacement with correct toner cartridge seems to the solution.
Oct 22, 2012 | Brother HL 2140 Laser Printer
When I scan documents there are multiple vertical lines about about an inch in from the right margin of the paper.
Hi there
Vertical lines in scanning indicates there is something like dirt between the page that must be scanned and the lamp that lights up and moves, making it impossible for the scanned to read the area where the dirt/paper/etc. blocks the light. this "obstacle" is probably between the glass and the light. Have a look.
Regards
Andre
Please come back and rate the answer.
Aug 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I need calibration paper for the DS mobile scanner
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jan 22, 2010 | Pentax DSmobile Path-Through Scanner
How to clean a DSmobile scanner. I am getting
Jan 21, 2010 | Pentax DSmobile Path-Through Scanner
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
Brother DS-600 DS Mobile Portable Scanner Logo
46 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
