Question about Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV
Samsung TV Model # UN60ES7150FXZA blinking off and on
Brand new Samsung Smart TV keeps on blinking off and on. We had comcast already replace box and have us a new hdmi cable and it still blinks off and on. I also updated the Samsung firmware. Help!!!
SOURCE: Samsung ltm1555B - lcd tv blinking on button
I am having the same problem with the blinking orange light
Posted on Aug 31, 2008
  • 108 Answers
SOURCE: i updated my lcd samsung firm ware and the picture went crazy .
you need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
Posted on Jan 08, 2009
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
Samsung led TV model UN40H6203AF no picture no sound no backlights. Flashlight test shows letters on screen after pressing menu button. Standby light blinks 5 times after turning on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 29, 2017 | Samsung 40" Black LED 1080P Smart HDTV -...
62in samsung smart tv starts to turn on when i press power on the remote but the screen doesn't come on it blinks like its goin to turn on but it dont no buttons on the actual TV unplugged already
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Nov 24, 2016 | Samsung Televison & Video
How can i fix my samsung tv ? there is a black screen , no image , the sound is okay & the red led is blinking 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jul 06, 2016 | Samsung UA-55F8000 55" Smart Multisystem...
I have an old tv with comcast cable. I want to switch to a smart tv that has only been used with netflix. how do i connect smart tv to my comcast cable
Adding a smart tv just requires adding an ethernet cable to your internet connection to the ethernet port on the set. The smart services on the set us a broadband internet connection to work.
Jun 18, 2016 | Vizio 42 in. LCD TV
Why won't my 46 inch Smart TV power on. The power on/off red light just keep blinking.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 18, 2015 | Samsung 5500 Series UN46F5500AF 46" LED...
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
Samsung BP96-01653A Model HL50A650C1F I believe that the lamp went out on my Samsung 50 in DLP TV about a week ago. The TV would not turn on and the green lamp light blinks. I ordered a new lamp, fr
This sounds like a case where jumping to a incorrect conclusion has not resulted in the fix your were after. The problem could also be related to the power supply. Before going for another part it is best to consult a Technician who works on these all the time and get a correct direction to go before ordering a lot more parts. if you check on the internet with the symptom and model /brand of your unit- chances are someone else has already had this problem and may have the solution there for you to take advantage of. Of course each TV is different but it might be a better way to proceed than just guessing.
Aug 09, 2012 | Samsung HL50A650 50 in. TV
Comcast Remote Control - Won't accept remote codes
To reset the remote control, just take out the battery from the remote control, and reinsert it after an hour or so. The remote control will reset itself.
After that try to set it up with the setup code said for your device. You might have to try many codes before getting a code that'll have the most functionality with your device.
Setup procedure and set up code list of many popular brand remote controls are given by these sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
Mar 04, 2017 | Motorola Televison & Video
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV Logo
163 people viewed this question
Jerry Greenberg
Jerry Greenberg
