Question about Sharp AR-235 Copier
Sharp AR 235
I am still geting the same ERROR F5-02 , I replaced the Lamp,
What else can we do.
Also I replaced The board that comes underneath the Lamp,
Thank You.
    Scholar:
  • 60 Answers
Did you clear the code? It's been a while since I worked on one of these but there is a diagnostic mode you need to go into. Something like:
C Interrupt 0 Interrupt
at that point the machine clicks and asks you for a test command number. Enter 14 and press the copy button. That should reset the code. If not try 15.
Posted on Feb 21, 2009
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
ERROR F5-02 call for service code AR 235 MODEL
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Jan 15, 2011 | Sharp AR-235 Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
I'm getting an E7-10 error message on my copier
10 Content CCD black level error
Details CCD black reference plate scan level
abnormality when the copy lamp turns off.
Cause Flat cable installation failure to CCD unit.
CCD unit error.
Check
and
remedy
Check flat cable installation to the CCD
unit.
Check CCD unit.
Is your lamp coming on? If so most likely the CCD assembly needs replaced, That would require replacing the carriage that contains the lamp and mirrors, the CCD is mounted to that and is laser adjusted at the factory.
Aug 02, 2010 | Sharp AR-235 Copier
Sharp AR 235 error code E1-11
Abnormality on the IMC board.
Try resetting by pressing # / interrupt / c / interrupt.
punch 14 and ok / enter.
restart your copier.
if it doesn't work you will need a tech.
Jun 17, 2009 | Sharp AR-235 Copier
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
U2-40
try a reset with sim 16 first, it just may go away
Aug 20, 2008 | Sharp AR-235 Copier
Sharp AR-235 Copier Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
