Question about Sony SnapLab UP-CR10L Digital Photo Printer
Ink ribbon is not broken and paper is jammed but when i switch on the machine, it say paper is jammed or ink ribbon is broken
3 Suggested Answers
  • 8 Answers
SOURCE: ink ribbon or paper roll error. the in ribbon is
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Posted on Jan 26, 2011
  • 8 Answers
SOURCE: ink ribbon was chewed up in my son snap lab and
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Unable to clean 51
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to visit your local Brother Authorized Service Center, you can find one by clicking here. Thank you for using FixYa! - Don't forget to rate our service.
Feb 02, 2010 | Brother Office Equipment & Supplies
Unable to clean checked paper jams there are none cant print
1. The switching arm assembly not engaged correctly
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the tiniest of cracks but ruins everything!
Jan 31, 2010 | Brother Office Equipment & Supplies
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Big noise
the only ribbon that i know of in these printers is the ribbon on the thernistor for the fuser if this came out then the fuser as melted together. pull the fuser out and try turning it by hand i think you will find that the hotroll gear has broken andthe 2 rollers are fused together. replace the fuser
Dec 02, 2009 | Lexmark Optra M410 Laser Printer
Hp 5440 not printing, changed ribbon and now getting flashing arrow key. Restarted, took ribbon out and put back in....usually it works.
Step 1
Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Step 2
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
Step 3
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
Step 4
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
Step 5
If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
Step 6
If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
Step 7
Try changing the toner or ink cartridge.
Step 8
If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Nov 19, 2009 | HP DeskJet 5550 InkJet Printer
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
Fax/printer is unable to print
Oct 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
22 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
