A lot of my buttons don't work, could they be dirty? How do I clean them?
CD player door won't open. CD tray is always turning. Tape player shuts off after 2 seconds
  • Audio Player... Master
  • 5,484 Answers
Servisol video 40 can be used to clean buttons and controls.
Posted on Jan 06, 2013
Cd tray won’t open
In the good old days, a CD drive would always have a small hole in the front. To open the tray, you would straighten a paper clip and press a button about 1/2" inside the hole. This releases the latch and starts the tray coming out where you can grab it.
This video shows you how:
Jan 02, 2018 | Computers & Internet
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
43 people viewed this question
 Grubhead
Grubhead
