Question about Microsoft Xbox 360 Console
Reset family setting password
My daughter's Xbox 360 password was set by someone else & need to reset it. It asks for favorite food but we do not know what was previously put in there so we can not reset it. How do we reset this so we can play it & reset it.
  • 7 more comments
  • apocdaemon Jan 19, 2009
    i have same problem, xbox told me to return the console to the retailer from which i purchased it from for a replacement. is there another way? like restoring the system to the factory default settings?
  • wazzup-kris Jan 25, 2009
    I have also that problem ! We can't remember the security question, and i'm from norway, so i cant call the xbox support thing .. :(
  • hugo1995 Jan 31, 2009
    I set a pass code for my sons xbox360 family setting but i forgot what i made it
  • danny176 Feb 04, 2009
    i have the same problem.is there some master code to put in somewhere?
  • peacockm Feb 04, 2009
    We have forgotten the xbox360 family setting password nor the answer to the security question.
  • Anonymous Mar 16, 2009
    i can't expects my friends
  • jlevy2515 Aug 05, 2010
    i dont have xbox live and when i first got my xbox, i put family settings on and cant remeber the password or reset password. what should i do
  • Josh Stacey
    Josh Stacey Dec 31, 2013
    i put a passwrod on friend request by accisend do any of u know how to delete that setting if icant remember my password
  • Collins456
    Collins456 Jun 20, 2017
    the smartphone before it will successfully boot up once again. frp bypass apk which could be made use of if a person swipes your Android os.
Here's what you need to do:
Turn on your xbox, go to System Settings. From there go to Console Settings. A window should appear that asks you for your password. If you don't know your password, then make up something. It will tell you your password is incorrect, click Reset Password".
You'll need to type in: YrYa
If this fails, then you need to follow these steps to reset your factory settings.
Turn off your xbox. Take your hard drive out (the bulge on the side of your 360. It says HDD on it.) by pressing the gray button, and sliding the piece out. Turn on your xbox, go to System Settings - Console Settings - System Info.
Press these buttons IN ORDER:
LT RT X Y LB RB Y (using the left joystick) go right ONCE A
After all of this is completed, a window should appear asking you if you would like to reset your system settings, press yes!
After all of this is completed, you'll need to turn your xbox off, put the hard drive back in, and turn it back on.
I JUST had this problem, and this is what tech told me to do... and it worked.
Good luck! Down with passwords!
Posted on Feb 19, 2009
  • 2 more comments
  • snipester10 Oct 25, 2010
    I guess the sequence of buttons depends on the serial number of your xbox, because I've tried over a dozen different sequences and finally this one worked. Thanks Alex!
  • tuyen bui Dec 29, 2010
    goto account.live.com put in your email address which you used on the setting then they will sent you a link to reset your password
  • charmd93 Mar 23, 2011
    WHAT GRAY BUTTON
  • VashM16 Jul 22, 2011
    I have console safety on, how do I disable that?
    With it on it won't let me reset the factory settings.
I tried all of the above, but nothing worked. I ended up putting a few of the tips together and was finally able to reset my Xbox 360 to factory settings without doing anything to the hard drive.
Go to System Settings, Console Settings, System Info. At this screen you should see the Serial number and Console ID along with a bunch of other info. Here you enter LT, RT, X, Y, LB, RB, up arrow, left arrow, down arrow and Y. You should then see a message asking you if you want to reset the Xbox to factory settings. Answer yes. You will have to set it up again, but it only takes a second. You just need to make sure that you have your internet info handy if you have to manually enter it. Otherwise, you are good to go in 4 questions.
Posted on Jul 10, 2009
  • 6 more comments
  • crazymarx Sep 07, 2010
    Thanx a million!!
  • richboyd71 Apr 12, 2011
    thank u so so so much man
  • Austin Jul 24, 2012
    the new xbox with everything built in wont let me access the system info?
    doesnt work with brand new xbox...?
  • top_flight_s
    top_flight_s Dec 02, 2012
    thank you very much..it worked!
  • james farmer Jan 14, 2013
    nope does not work with new
  • justin perotti Mar 19, 2013
    dose it keep your profile
  • joee
    joee Dec 16, 2013
    i go to to System Settings, Console Settings, System Info but i cant write the button it dosent write
ATTENTION:
For all people having issues with family passcode reset.
console settings<<<system info
*** Look at your serial number*** at the top. xxxxxxx xxxxx
write it down!
now
Call 1-800-4my-xbox
Please dont think you will be given the run around over the phone..
They will help.
First they will ask you a series of questions,,like gamer tag,,billing address,ect.
Then they will ask for your serial number. ( xxxxxxx xxxxx )
Next, after giving the serial to xboxlive tech support, they will give you back a sequence of game controller entries to reset the console.
Something like this:
( LT + RT +X+ Y + LB+ RB ) + Plus four destictive presses, associated with your serial number.
So: it will be something like, LT + RT +X+Y +LB+RB +(LEFT+LEFT+UP+A )
All xbox 360's are different.
The serial in <system info> is the key to your indivisial passcode reset.
MIne is (up+up+left+y)
My buddies is(a+a+left+left)
Your's will be different.
If you bought a used xbox360, make sure you get the serial from your system info in your dash.
Used xbox 360 may have had the guts swapped, and may be different.
So: Grin and Bare it, and make the call.
5 to 10 hold time..not bad
good luck
OUCHIE 666
Posted on Apr 14, 2009
  • 1 more comment
  • spenc11 Jun 08, 2011
    dude i was looking at what u said.
    So:it will be something like, LT + RT + X + Y + LB + RB + (LEFT + LEFT + UP + A )
    and it worked i am so happy :D i was just skimming threw this page when i noticed the enter stuff so i was reading threw it and it just so happened to work OMG I AM SO HAPPY I CAN NOW JOIN XBOX 360 LIVE OMG URE LIKE SUPER MAN TO ME LOL
  • sina Jun 07, 2013
    I did it but I didn't see the box that is saying you want to reset the password.and I think the problem is my Xbox everything it is its a stupid thing
  • Ali Yekrangi
    Ali Yekrangi Jun 28, 2014
    Hi if you wanna give me a serial console, you can give me an Xbox Reset Code. Xbox is not supported in my country
Here is what i tried on my Xbox 360 and it works (LT RT X Y LB RB) this what start the reset, after that u have to punch 4 more buttons i did a trial and error thing here is the list of what works so far LT RT X Y LB RB B B X X LT RT X Y LB RB Y B A X LT RT X Y LB RB left left X X LT RT X Y LB RB up up X X LT RT X Y LB RB down down X X LT RT X Y LB RB right right X X LT RT X Y LB RB X X X X this one works on my friend Xbox 360 too and i sure there is more :) good luck
Posted on May 26, 2010
  • oddo310 Jun 28, 2011
    I agree that LT,RT,X,Y,LB,RB,X,,Y,A first is the sequence to ulock then the Dpad combo is what may be different for all X-boxes. For mine I did the sequence abovr then I did L,L,L on the D-pad. So just try different D-pad combos after the unlock swquence and it should work.
  • aaronleveill
    aaronleveill Jul 20, 2012
    first one worked great for me thanks!
Let me make it easy for all of you.
LT,RT,X,Y,LB,RB,X.
this is the correct reset code. you're welcome.
Posted on Aug 05, 2010
  • 4 more comments
  • bigdog619 Oct 25, 2010
    This is the only and secure solution, it will reset everything to factory settings.
    You're all welcome.
    1- Go to System Settings.
    2- Go to System Info.
    3- On the Info screen enter:
    LT, RT, X, Y, LB, RB, up, left, down (using the D-PAD arrows), X.
    This will reset everything to Factory Settings.
    3- On the System Info Screen enter:
    LT, RT, X, Y, LB, RB, up, left, down ( using the D-PAD arrows), X.
  • bigdog619 Oct 26, 2010
    This will reset everything to Factory Settings ( xbox 360 only).
    Enjoy your XBOX360 again.
    Make sure you write this down
    1. Go to System Settings.
    2. Go to Console Settings.
    3. Go to System Info.
    4. On the System Info screen enter:
    LT, RT, X, Y, LB, RB, up, left, down ( Using the D-PAD arrows ), X.
    It will ask you if you want to reset to factory settings,select yes.
  • fishtrombone Feb 08, 2011
    thanks for the help
  • master_kyle9
    master_kyle9 Nov 08, 2012
    where are we supposed to enter it there is now keyboard
  • master_kyle9
    where do you enter it at there is no keyboard
To completley reset family setting after forgetting or not knowing the password- do a factory reset, go to system settings, console info at the screen u should see your serial and consoles dashboard info. press left trigger, right trigger, x, y, left bumper, right bumper, up, left, down, y. this will not effect your hdd only reset any console info to factory settings. ;)
Posted on Jun 23, 2009
Go to system settings then system info and press LT, RT, X, Y, LB, RB, up arrow, left arrow, down arrow and Y. it pops up a littel thing that says reset SETTINGS to factory defaults press yes!!!!! it worked for me but then my dad foundout
Posted on Jun 08, 2010
I JUST GUESSED MY ONE;MY LAST FOUR - LEFT LEFT RIGHT X
Posted on Mar 14, 2010
System settings> console settings> system info> LT, RT, X, Y, LB, RB, (on the D-pad) UP, LEFT, DOWN.
this worked for me when none of the other posts worked hope it works for you
Posted on Mar 13, 2011
First proceed to My Xbox, then Cnsole Settings, then press in this order: Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, X, D-pad: left, down. This will start the process, eventually restarting the console. Please also be aware, I don't know what else will be asked of you once you restart, I have not had to utilize this yet, but thanks to google, found the answer.
Posted on Jun 22, 2009
Thanks ncollatos
Posted on May 09, 2010
Hi
my dashboard has 2.0.16747.0 how do i reset the xbox
plz help :)
Posted on Jun 28, 2014
Every one has there own special code to put in just call xbox and they will help you, it takes about 5 mins to fix,
Posted on Jan 01, 2010
Okay i did that, reset the settings and so on but i still have the family settings, wasnt this suppossed to get rid of it??
Posted on Nov 24, 2009
Try buying a new hard drive and a data transfering device and transfer your profile and only your pro file to the new hard drive. you should then have no family setings on your new hard drive.
remember to buy all this second hand from a good shop like GAME.
Posted on Oct 09, 2010
This still didnt work
Posted on Nov 26, 2009
  • 3 Answers
Dont disturb
Posted on Apr 10, 2010
  • rizvinasser Apr 10, 2010
    we have forget our familysetting passcode give us a passcode to unlock the code
  • 5 Answers
Its more simple than all these strings of characters. Just follow these instructions from xbox.com
http://support.xbox.com/en-us/xbox-360/troubleshoot/kb/xbox-kb-911059
Just reset our xbox and got rid of the family password.
Posted on Nov 26, 2011
Omg ure um thingy was right omg i am finally able to join xbox 360 live wooooo i wasnt able to because of my family settings and now ure the coolest dude in my life and i dont even know u@@@@@@@@@@@@@@@@@@@@@@@@@@@ THANKS ALOT URE SUPER MAN!!!!!!!!!!
Posted on Jun 08, 2011
    New Friend:
Can you help me with my xbox 360 of the family setting please
Posted on Oct 24, 2016
My cuz changed my privacy code and now i cant play gta or watch movies can some one give me advice to play games and watch movies
Posted on Apr 29, 2013
Thanks first code saved my hind.
Posted on Jul 14, 2012
How do I reset my favorite movie question, answer
Xbox accounts are now considered microsoft accounts so you can reset the password, questions, etc. at live.com from any computer. If you haven't logged in from that computer, it will ask for verification. Which means texting/emailing/etc a pin code to you and you keying it in on the website. Once that code has been entered, it should let you update your security questions, password, etc.
Oct 17, 2014 | Microsoft XBOX360 By Yallstore
My daughter&#39;s Xbox 360 password was set by someone else &amp; need to reset it. It asks for favorite food but we do not know what was previously put in there so we can not reset it. How do
  1. Go to www.xbox.com
  2. click "sign in"
  3. click "Cant Access my account"
  4. Follow the steps it gives you and you will reset your password.
If you still cant do any of that try contacting Microsoft.(link attached)
Disability Answer Desk
Sep 24, 2014 | Microsoft Xbox 360 Console
Family setting off the xbox 360 without knowing the passcode
Please contact the XBOX Support hotline to recover the default settings
http://support.xbox.com/en-US/contact-us
Nov 24, 2011 | Microsoft Xbox 360 Console
Forgot the answer to the passcode question: my favorite food, for my kids xbox 360
Your best bet is to call Xbox Live support and talk to them. They will most likely ask for your billing info/credit card information so make sure you have it on hand. This is the fastest and probably the only way you will be able to reset it.
May 01, 2011 | Microsoft Xbox 360 Console
I don't know how to make my console safety off because i have forget it's password.
Mar 05, 2011 | Microsoft Xbox 360 Elite Console
Xbox360 password recovery or reset
Nov 25, 2009 | Microsoft Xbox 360 Console
I need my xbox fix
Do you have a family settings turned on?
If you do you should be able to go back and restore your xbox to its default settings.
Mar 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
Aug 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 family timer
Try Unplugging it for an hour or so (like how power outages ask you to set up your console) and ask him if he knows it...
or de attaching the HDD :) it's removable you know!
so much power for a little kid :(
Feb 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
74,906 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
