Question about Dell Vostro 220 Desktop Computer
My scoll bar is not showing on my main screen. How do I adjust to have it fit?
  • Official Brand Answer
  • 560 Answers
Kim Drader,
Below are steps to resolve your scroll bar issue.
Instructions
  • Restart your computer Sometimes, a simple restart can bring back the scroll bar to its original form.
  • Right-click anywhere on your desktopmy scoll bar is not showing on my main screen.  Ho - icon1.png. Click on "Properties" if you are using Windows XP. Select "Personalize" if you use Windows Vista or Windows 7 and click on "Windows Color and Appearance." Then click on "Open classic appearance properties for more color options."
  • Click on the "Advanced" button.
  • Click on the "Item" drop-down menu. Select "Scroll bar."
  • Change the width by entering "17" under the "Size" category. 17 is the default scroll bar width for Windows operating system
  • Click on "OK" and select "Apply" to end task.
  • Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
    Posted on Jan 08, 2013
    How can I set time and volume?
    These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
    From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
    Look for, and tap on "Change preferences".
    1. To set Time:
    On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
    2. To set Volume:
    On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
    Feb 11, 2016 | Tomtom One GPS
    I would like to disable scoll bar on my e systems 1201
    Go on your browser, I use Firefox, and click view at the top right corner of the screen and click full screen. Or just hit the F11 key.
    Sep 08, 2013 | E-Machines Computers & Internet
    I can not find a bar to fit the rancher 55. This
    The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
    Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
    How to zoom in on info
    When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
    1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
    2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
    3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
    4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
    5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
    6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
    7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
    8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
    9. Exit the menu when you are done and watch your programming normally.
    Feb 04, 2011 | LG Televison & Video
    Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
    The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
    Jan 24, 2010 | Toshiba Computers & Internet
    My sony vaio laptop PCG-3E2L shows the logo and shows the windows vista scolling bar... after that it goes to a black screen of a long time then restarts. I tried to load it in safe mode but just...
    If it is still under warranty then get it repaired under warranty, because if you try to fix it yourself and do further damage you most likely would void the warranty.
    Jun 19, 2009 | Sony Computers & Internet
    Turned on loud feature need to turn it off
    Press the source button, press the volume knob for at least second, then press the volume button again, and then turn the volume knob and it it will scoll through the adjustments, the last one should be loud and press the volume button again to select off, press and hold for at least one second until it returns to the main screen, then you should be set
    May 12, 2009 | Kenwood DPX-301 CD Player
    I have a 57x500 Hitachi ultravision digital t,v,.....When we try to watch DVD Movies or vhs,the screen has the dark side bars on the side,,how do adjust the screen to make the movies fit on the screen so...
    On your remote there should be a button that says "Aspect" or "Pic Size". Press thisuntil the video fills the screen. If you do not have the remote of don't have the original remote, this setting can be found by preesing the menu button on the tv, go down to video settings and it should be listed under "Aspect Ratio", change it untill the video fills the screen.
    Dec 30, 2008 | Hitachi 57F500 57" Rear Projection...
    Main LCD
    Check with the Software of the mobile,try to reinstall the software in mobile,not solved show the LCD Screen from authorize service center.
    Jan 17, 2008 | NEC 535M Cellular Phone
    Picture slants right to left
    Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
    Dec 16, 2006 | Philips 27PT5445 27" TV
    Dell Vostro 220 Desktop Computer   Logo
    51 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
