Question about Whirlpool ET8WTKXKQ 18.2 cu ft Top Mount Refrigerator
Water is going into the bottom of the refrigerator
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
Why do have water below my lowest shelf
your drain line may be plug up therefore is going above the level make sure you see water on the bottom tray next to the condensing coil under the refrigerator.
thanks.
Aug 11, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Where does water go when it defrosts?
The water will go into a drain pan which is located at the bottom of the fridge. The hot discharge line from the compressor is in the drain pan which during normal operation will evaporate the water.
Aug 31, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking in 1997 GE refrigerator,top freezer type
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Mar 27, 2011 | GE Refrigerators
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool ET8WTKXKQ 18.2 cu ft Top Mount Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
