Question about Irons
Need electric cord for heat press
I recently acquired a Bernette PE 380 heat press, and it does not have a cord. Does Bernette only have sewing machines now? Do you know if another company took over the heat presses? I can't seem to find a cord anywhere.
Thanks in advance for any help you may be able to give me. Susan Nicolas
    New Friend:
  • 4 Answers
A heat press is the machine that presses a transfer onto an printable substrate. Using high temperatures and heavy pressures for a certain amount of time, the transfer is permanently embedded into the product. Its can be used to print pictures or anything on t-shirts, bags etc. To solve your problem you can click here.
Posted on Apr 20, 2017
I just aquired the same iron-- do you have the manual? I was told there was a place to add water and am unable to figure that out.
Posted on Jan 10, 2011
Singer 7467 wheel won't spin, unless little bit if I do manualy by hand...
do this
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.2_1_2013_6_01_09_pm.jpg
Jan 31, 2013 | Singer 7467S - Confidence Sewing Machine
Iron will not heat
see the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 22, 2012 | Rowenta Irons
Will not heat
see the causes and proceed according. fix it. God bless you
Sep 22, 2012 | Rowenta Advancer Iron
Is no workig i needcramic heat control
1. you need a multi tester.
2. check the power supply of your outlet, or check the fuse or circuit breaker.
if has power go to 3.
3.open the back of your electric iron, the end of the cord or plug. then try to check the continuity of two wires if any is open. if its open or no continuity replace the cord or plug, either cut the only open wires and reconnect it again.
4. Or check the heating element of your electric iron if no resistance replace the heating element or you buy a new one.
Feb 16, 2011 | Conair Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
I have to jiggle the cord for the iron to heat.
The cord is broken right where it eters the iron...
Take it apart, mark the wires, cut the cord bach 6 inches and reattach it...
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 18, 2010 | Rowenta Irons
Turned on my iron and it does not heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
Jun 21, 2010 | Rowenta Sew 'n Press Iron
My iron has a mind of it's own! It will heat for
You need to replace the cord...
heatman101
Aug 29, 2009 | Rowenta Professional DX8900 Iron
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Mar 26, 2009 | Rowenta Irons
Irons Logo
231 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
