My monitor [SE198WFPv] is stuck in self test mode, what do I do?
Accidentally touched the far left of button of the right side and the self test for color started and won't stop. I was not using it with the inspiron because it's broken. I was using a dimension 2400 Dell.
  • 4,806 Answers
Hi.
Try unplugging the monitor from the mains for a minute or two then plug it back in, see if that works.
Regards.
Posted on Jan 02, 2013
  • Lillian Dean
    Lillian Dean Jan 02, 2013
    I wrote this once but the telephone rang and when I got back it was gone, so here goes again. that was the first thing I tried, but it didn't work. I'm thinking I need to get it's cd out and see if I get any where then, sound reasonable? Thanks for helping Lillian
byron21
  • 151 Answers
SOURCE: Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Posted on Sep 24, 2009
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
SOURCE: how to fix a dell monitor dimension 2400 power button broken
The last guest left us hanging with, "easy fix" so, I ventured ahead to see what I could see by opening up my lcd, which was a puzzle in itself. After UNPLUGGING the monitor and removing the stand and the 4 obvious screws in the back, turn the monitor onto its back and placing your palms against one side of the monitor, and using your FINGER TIPS, gently pull back the plastic lip away from the LCD screen. Move along the lip, doing this a little bit at a time. You'll hear and feel it snap loose. Repeat on the remaining three sides. It may take a few rotations to free all the sides, doing a little at a time, so as not to put undo stress on the plastic that is not yet loose. The bottom lip from behind which lies the offending "on/off" button will not move as freely as the other sides because of the ribbon cord that attaches the circuit panel to the main body. So STOP pulling when you feel it become taught and carefully turn the monitor onto its face to complete the face's removal. Undo the cloth tape that secures the ribbon cable to the monitor. This will give you the necessary slack you need to do your dirty work. BTW, we're not disconnecting the ribbon cable from its connections- that would be bad - just remove that haphazardly placed piece of tape used to keep the thing snug and save it for when you're ready to close it back up. OKAY! There a four tiny screws that affix the green circuit board. You'll need a thin, jewelers type phillips head or a one from a synthe-sized tool set to remove these. Now, if your issue is like mine, you'll see when you again carefully remove the circuit board, that the on/off button has cracked off of the piece that holds it. This is why the button remained stuck in one positon when it was depressed. Re-align it so that it is uniform to the other buttons and place a few small strips of cut electrical tape to hold it in place to the end where it broke off. Crazy glue or the like won't give the button the flexability it needs and will probably just crack again. What the tape (I layered 3 strips) will do, once the circuit board is scewed back, is allow the button to return to position after it's pushed. I just did this and so far, after a dozen on/offs it's still working. Good luck. Go have a beer.
Posted on Jul 14, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
Asus monitor vw224u stopped working, found was partially unplugged, plugged back in, rebooted, shut down, restarted but monitor says no VGA signal
Try pressing the S/A button to change input sources.(the button on the far left on the front of the monitor) Chances are the cable got unplugged, then the monitor when into analog mode and its now stuck there, because many monitors default to analog.
Feb 27, 2011 | ASUS VW224U 22 inch Monitor
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
Dell SE198WFPv LCD monitor won't turn on.
try it on different computer and if it doesnt work replace costs more to fix than replace
Jul 06, 2009 | Computers & Internet
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
I have 3 codes that showed up in the computer of my 1995 Ford Windstar
Here is the first half of the codes look till you find the one you have
111 System PASS.
112 ACT sensor circuit grounded.
113 ACT sensor circuit open.
114 ACT sensor is out of Self-Test.
116 ECT sensor is out of Self-Test.
117 ECT sensor circuit grounded.
118 ECT sensor circuit open.
121 TP sensor is out of Self-Test.
122 TP sensor input is less than Self-Test minimum.
123 TP sensor input is greater than Self-Test maximum.
124 TP sensor input voltage is greater than expected.
125 TP sensor input voltage is less than expected.
128 MAP vacuum hose damaged or disconnected.
129 Insufficient MAF input.
136 HEGO sensor circuit indicates system lean (Right HEGO).
137 HEGO sensor circuit indicates system rich (Right HEGO).
139 No HEGO switching (Front Side).
141 Fuel system indicates lean.
144 No HEGO switching (Left Side).
157 MAF sensor circuit open.
158 MAF sensor shorted to power.
159 MAF sensor is out of Self-Test.
167 Insufficient TP input change.
171 Lack of HEGO switching (Rear Side).
172 HEGO sensor circuit indicates lean. (Rear Side).
173 HEGO sensor circuit indicates rich. (Rear Side).
174 Check for diluted engine oil.
175 Lack of HEGO switching (Front Side).
176 HEGO sensor circuit indicates lean. (Front Side).
177 HEGO sensor circuit indicates rich. (Front Side).
178 Check for diluted engine oil.
179 Fuel system at part throttle lean adaptive limit, system rich (Rear Side).
181 Fuel system at part throttle rich adaptive limit, system lean (Rear Side).
182 Fuel system at idle lean adaptive limit, system rich (Rear Side).
183 Fuel system at idle rich adaptive limit, system lean (Rear Side).
184 MAF sensor input voltage is greater than expected, in range.
185 MAF sensor input voltage is less than expected, in range.
186 Closed loop injector pulse width longer than expected.
187 Closed loop injector pulse width shorter than expected.
188 Fuel system at part throttle lean adaptive limit, system rich (Front Side).
189 Fuel system at part throttle rich adaptive limit, system lean (Front Side).
193 Flexible Fuel sensor circuit failure.
211 PIP circuit failure.
212 Loss of tachometer/IDM input.
213 EEC SPOUT circuit open.
214 CID circuit failure.
215 PCM detected coil 1 primary circuit failure.
216 PCM detected coil 2 primary circuit failure.
217 PCM detected coil 3 primary circuit failure.
218 Loss of ignition diagnostic monitor signal-left side.
219 Spark timing defaulted to 10 degrees, spark output circuit open.
221 Spark timing error.
222 Loss of ignition diagnostic monitor signal-right side.
223 Loss of dual plug inhibit control.
224 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
225 Knock not sensed during dynamic response test KOER.
226 Ignition diagnostic monitor signal not received.
232 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
238 PCM detected coil 4 primary circuit failure.
241 Ignition control module to PCM ignition diagnostic monitor pulse width transmission error.
244 Cylinder Identification circuit fault present when cylinder balance test requested.
311 Secondary air injection system inoperative during KOER self-test (bank #1).
312 Secondary air injection system misdirected during KOER self-test.
313 Secondary air injection system not bypassed during KOER self-test.
314 Secondary air injection system inoperative during KOER self-test (bank #2)
326 PFE sensor circuit voltage lower than expected.
327 PFE sensor circuit voltage below Self-Test minimum.
328 Exhaust gas recirculation valve position sensor closed voltage lower than expected.
332 Insufficient EGR flow.
334 Exhaust gas recirculation valve position sensor closed voltage higher than expected.
335 PFE sensor circuit voltage out of Self-Test range.
336 PFE sensor circuit voltage higher than expected.
337 PFE sensor circuit voltage above Self-Test maximum.
338 Engine coolant temperature lower than expected (thermostat test).
339 Engine coolant temperature higher than expected (thermostat test).
341 Octane adjust service pin open.
381 Frequent A/C clutch cycling.
411 Cannot control RPM during KOER low RPM check.
412 Cannot control RPM during KOER high RPM check.
415 Idle Air Control system at maximum adaptive lower limit.
416 Idle Air Control system at upper adaptive learning limit.
452 Insufficient input from VSS.
453 Servo leaking down.
454 Servo leaking.
455 Insufficient RPM increase.
456 Insufficient RPM decrease.
457 Speed control command switch(s) circuit not functioning.
458 Speed control command switch(s) stuck/circuit grounded.
459 Speed control ground circuit open.
Jan 15, 2009 | 2001 Ford Windstar
Self timer
Press the "function set" button to the right of the display, then press the "scroll down" button (or six o'clock position on the ring around the function set button) until the square box on the left side of the display is highlighted. It will say "drive mode" at the bottom of the display. Press the scroll left or scroll right buttons (or nine and three o'clock positons on the ring) to select the time for the shutter delay. Don't forget to reset the selection back to normal mode (square box icon).
Far more complicated than it needs to be and the manual is useless.
Dec 13, 2008 | Canon PowerShot A520 Digital Camera
Pushed wrong button
You got a clue by now and pushed that button 2 more times, right? And the Rapture happened and it went back to right? Yep. No problem. Keep that PDF manual for the monitor around for light reading, too.
It seems like the right button to push to me, too. Maybe if I had CCTV on the doorbell or backyard or something it would be; otherwise it is the one third from the left.
Feb 20, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
