Could you please send me instructions on how to set the timers.
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I lost the instruction booklet.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
EJ500 instructions are fairly long. Re-post if you have a problem following manual.
SOURCE: I lost instructions for setting my 111 Woods
Merry Christmas to you also.
I do not show a Woods 111 timer.
However Woods is sold under many different numbers and a few different brand names.
Link below goes to all Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Step 1) Scroll through page and look carefully at the timers to help identify your timer. Similar timers might set the same way as your timer. Add a comment any time.
Step 2) Add a comment and describe your indoor timer. Is it wired into the wall, or does it plug in. Describe the buttons in detail or the dial, describe override switch if it has one. Give as much information as you can think, and then I will check other resources
Step 3) Check list of other brands because Woods carries over into other brands as well. I am familiar with these timers.
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
SOURCE: I lost set up instruction
I have not heard of Woods 59732
You posted next to a photo that shows Woods 49063
Woods has many different numbers for same timer.
Manuals show for each timer on page
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Woods has 59730 yard stake:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Other pages you can look at to identify your timer:
Add a comment for more free help, and say what buttons appear on timer.
SOURCE: Salter 4-way timer instructions I have
http://waterheatertimer.org/pdf/Salter-4-way-timer.pdf
