Question about Hardware & Accessories
I want to know how to set the time on my swimmimg pool timers
  • 5,089 Answers
Hello Gerhard
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Posted on Jan 03, 2013
The supplier that fiited my swimmimng pools timers never gave me the booklet on how to set the time.
2) For Tork:
3) Jan 2013.
Jan 02, 2013 | Hardware & Accessories
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need to reset the timer on my 633T Krystal Clear pump as we have unplugged the power and we can't get the timer to work.
You know the timer can only be programmed once and it is 24 hrs after the last time it ran. So turn it on at the exact time of day you want it to run every day, set the dial to how many hours to run and walk away. It should start up automatically 24 hrs later each and every day (as long as you have the on switch set to the timer position)
Jul 12, 2011 | Intex Krystal Clear Model 635 Pool Filter...
My intermatic pool tmer will not set time or let me auto. turn to on so I can't filter or backwash pool
Problem points to electric power.
1) For best possible free answer, please add a comment and give model number that shows inside timer door.
This will give expert access exact manual for the equipment you have, and show what voltage you are working with.
2) You can also review Intermatic pool timer sell sheet, and pool timer site to help identify product:
http://waterheatertimer.org/pdf/Pool-and-spa-catalog.pdf
http://www.poolandspacontrols.com/products.aspx
3) If you have mechanical dial timer, see if manual override works.
And then check electric power.
Check circuit breaker.
Check if manual override works.
4) If you have P1353 digital electronic timer:
http://waterheatertimer.org/images/P1353ME-digital-time-clock-mechanism.jpg
P1353 digital electronic timers have auto setting.
Check programming.
Programming for P1353 is complicated, and longer than space allowed for free answer.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
Programming starts on page 25, and you can add a comment about any specific part of manual that is confusing.
Mar 09, 2011 | Intermatic Timer T12404R Pool & Spa...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Pool timer is set but when i turn the switch to on
leave it in the off position and wait til ten to see if it comes on. typically the timer will flip the switch on itself..
Mar 14, 2010 | Intermatic T104 24h 208-277v Mechanical...
I have an old pool timer. How to set it?
yes there should be 2 tab on the wheel one for off one for on set the wheel to the correct time by pulling it up which is printed on the wheel. then set the tabs to your desired time.
Jul 10, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
194 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
